Question about Dryers
Kenmore HE3 Dryer not drying clothes unless on high!
Acute Stated problem fixed; Dryer ran but had no heat. Happened on 3/27/08 fixed morning of 3/28/08. I replaced Thermal fuse. That was the malfunctioning part causing that problem.
Long term problem; Dryer has to be on high and run for 80 minutes to dry clothes. Cannot use any of the programmable cycles. Clothes don't dry at all when using that option or any heat setting other than high.
Trouble shooting attempts so far; Called Sears repairman three times unit was under warranty at time of calls. They did not resolve problem and said it was because the venting was to long. I did not believe but changed any way. I have checked to see if vent is clear. I have moved it based on sears repair man. It is now straight up 8 feet and out two ninety degree bends that is it . It is not the venting Sears. I have narrowed it down to the Thermistor part #8577274, or`Thermostat part # 3403140, or the sensor, radiant part # 338906. I am not a trained technician but thought this was logical approach.
I have given up on Sears repair they are very disappointing. Can you provide any starting point based on issue with unit. I have no clue! Also do you think it could be the control board? Let me know your thoughts. I would appreciate that very much.
Randy
Email: randy@paradigmfmg.com
  • Anonymous Jul 08, 2008
    i have the same problem. the dryer is running the air is blowing but it is cool...it begins to get hot then stops...we checked all the vents, etc. I have called Sears and have a warranty but unreal- they said they cannot come until 17 days! We will see if they can fix it...I have made a copy of these problems and plan on giving it to the repairman so hopefully I won't have a similar situation
    President:
  • Dryers Master
  • 2,651 Answers
Interesting issue, with the number of parts you providied id be willing to ri\ule out the thermistor #85777274(genarlly when this goes bad you get a fault code of some sorts}, and also the 3403140( youd get absolutly no heat if this part were bad.), and lastly the flame sensor is doubtful as well probly replaced 2 in my whirlpool career( the window may be dirty and need wiping but problably not that either. I honestly would have went with hthe sears guy as far ads the venting, its the number one issue with all dryeres. too long to dry = innadaquate vent . but being youve ruled that out as well. trust me an ew vent is woth the 30 dollar investrment you took.
id be willing to bet you have a bad set of valve coils(locatged ontop of the gas valve, easily replace for about 20 bucks. what ends to happen is that they fire just fine for the first 20 min or so of the cycle and then the get too hot/ overheat adn dont allow the flame to reignitre for the last portion of the drying period. untill the cool down enought to once again fire the flame.. part #279834
I woulda replaced them the second time out just to rule them out (if i was the sears guy) sure he had at least 6 sets on his truck ( i know I do)
Posted on Mar 29, 2008
I have a similar issue. I was confused by this posting. Did the "Thermal Fuse" fix this issue, or did replacing the coils do the trick? Also, is the two coil part 279834 a valid repacement for the 694540 & 694539?
Posted on Jun 21, 2008
Have an HE3 Kenmore elite gas dryer. It is taking longer to dry the clothes than it did when it was new. Is there any maintenance I can do to improve the time?
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope you find this information helpful.
Aug 03, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
No heat
take off the back of the dryer you will see wires to the lint tube thats heating elements take the removeable plate off and see if its clogged with lint if so clean it out that should fix it if its not elements are probably bad. its also easy fix
Oct 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 dryer stays cold
you probably need a new heater element.
Dec 12, 2008 | Kenmore 82822 Electric Dryer
Not Drying
Had the same issue with my Whirpool. If the clothes are getting hot but not drying then there might be a build up of lint in the exhaust duct and/or passage. Once I replaced the the duct and ran a snake with a brush through the passage (my dryer was on 1st floor, vent ran up to 2nd) and cleaned out the lint build up in filter area it worked like new. Also keep in mind if you use dryer sheets they will leave an invisible residue on your lint filter thus restricting airflow. This can lead to the heating element burning out. The lint filter should periodically be scrubbed with a soft brush (an old toothbrush will do) under warm water with detergent (I use Dawn). This should keep the airflow moving through the dryer instead of keeping it in the drum. Hope this helps.
Oct 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryers Logo
1,478 people viewed this question
Top Dryers Experts
