Question about Raypak Spapak Electric Spa Heater - Els1102 - 2 - 11 Kw
Just replaced the heating element on my Raypak 1102-2 Turned the unit on & the on light didn't come on. Did i replace the element for nothing? What could the problem be THANK YOU
  • 990 Answers
Check your high limit. This is the reset switch behind the rubber button on the face of the heater. It probally tripped during the process and didn't get reset.
Posted on May 13, 2010
No Heat on My Raypak 1102-2 Spa Pak
check pressure switch if not enough pressure not enough voltage to complete circuit make sure filters are clean
Dec 14, 2013 | Raypak Spapak Electric Spa Heater -...
My Raypak spapak 11kw 1102 has deveolped a leak at the base of the heater tank. Small pin hole leaks in the copper tank. This is the second one to leak (replaced one two years ago) at the same place? Why...
make sure pool chemistry is in balance too low of PH and too low alkalinity will eat through the heat exchange copper PH should be between 7.2 and 7.8 alkalinity should be between 80 and 120
Oct 01, 2012 | Raypak Spapak Electric Spa Heater -...
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 21, 2011 | Kenmore Dryers
Dead, has power going into wiring, but wont do anything no lights or nothing could it be the thermal fuse?
It is almost definitely the thermal fuse. However, you also need to determine why it blew the thermal fuse. This fuse is in place to protect the Control Unit from overheating cause by to high of an amp draw from the motor, the heating element, or a dead short in one of the solenoids.
Replace the thermal fuse, which is located on the Control Unit, behind the Control Panel. After replacing the thermal fuse, start the dishwasher and using an amp meter, test the amp draw of the unit at the supply connection.
During the water fill, you should only see 0.1 to 0.2 amps at the most, and possibly could show 0.0 amps. Once the wash motor turns on, you should see somewhere between 1.2 and 1.8 amps. If the amp draw goes over 2.0 and stays there, you have a bad wash motor.
The best way to check the amp draw of the heater is to put the unit into a field diagnostic mode. To do this, cancel the cycle and wait for the unit to shut down (standby mode). In this order, press "HI TEMP WASH - AIR DRY - HI TEMP WASH - AIR DRY". Air Dry could also be labeled No Heat Dry or something similar. All of the LEDs will light up momentarily and the heat element will be turned on briefly. The amp draw of the heat element can read from 5.5 amps to 7.0 amps. If the amp draw of the heat element goes above 7.5, chances are that your heat element is bad and needs to be replaced.
Apr 17, 2011 | Dishwashers
I've had my Raypak SpaPak (smaller model) for about 2 years. It seems like it doesn't seem to heat the water as hot as it used to - I need to turn the dial to a higher setting to bring the pool up to...
If you do not keep close watch on your water chemistry, depending on your location , you could have a large calcium build-up or salt build up on your electric heating element. Also, these models are meant for spas, and depending on the weather in your location, the heater might have trouble keeping up.
Mar 23, 2011 | Raypak SpaPak Spa & Hot Tub Electric ...
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
Turned on oven, waiting for it to heat up and saw a bright flash of light and now nothing works control panel doesn't even light up
the bake element shorted out turn of the power to the unit and replace the bake element or bottom cooking element that will fix it
Apr 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Raypak Spapak Electric Spa Heater - Els1102 - 2 - 11 Kw Logo
338 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
