Question about Pioneer Audio Players & Recorders
Receiver: Pioneer Elite 72TXV Verizon
Verizon Fios DVR: Motorola QIP6416-2
HDMI Connections.
I intermittantly lose audio signal from cable box. Video is still processing through the receiver to the TV. HDMI light flashes as if it's trying to find a signal.
With same connections I have no problem with DVD player. I have tried switching cables and switching inputs for HDMI to no avail.
Any ideas?
Steven Lakso 714-842-9511 slakso@verizon.net
  • 1 more comment
  • Anonymous Mar 16, 2014
    Changed bluray player and Hdmi cable still happens ocassionaly
    video displays correctly ,connected with hdmi cables. no surround fom all speakers.dish 722 satellite receiver sharp lc55620ut tv
  • Anonymous Mar 24, 2014
    HDMI light is flashing. Tried to find fuse but I can't.
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
  • Kirk C Tellier
    Kirk C Tellier Feb 18, 2014
    So this helps me how?
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
I lose my audio often for non-hd channels with dish 622 dvr
The problem could lie in youir HDMI cable, this is a common issue. if you swap HDMI cables and still have the same problem then bypass your A/v rec and connect your 622 direct to your tv and see if the problem persists, it it does, then your DVR needs to be replaced, you can call dish for addition troubleshooting if it is in fact your DVR.
Nov 10, 2009 | DISH Network ViP622 DVR DTV Receiver /...
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
Hook up vizio tv to fios box
Run HDMI from FIOS to TV directly, then run Digital coaxial or optical to the cbl/sat audio input of your receiver. That's it. If you have any more questions, just post a comment and I can help more.
Aug 08, 2009 | Pioneer VSX-D509S Receiver
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Download from FiOS DVR (Motorola Box) USB port is disabled by Verizon to preclude lawsuits by content providers and Movie Industry, but the ability is contained in the box.. I want to download and save...
If you have audio/video connections out of the dvr then that will work , otherwise use a hdmi to a/v converter with red white and yellow connection and use a dvd recorder.
Jul 22, 2017 | Motorola Televison & Video
Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Jun 11, 2009 | Onkyo TX-SR605 Receiver
449 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
