Question about Kicker 05C104 Car Subwoofer
Hey i just got a 8" inch kicker and i want to know how do i connect it from the back.
    Problem Solver:
  • 8 Answers
There are 2 components, so all you do is put wire from the red (+) to the (+) output on your amp. and then you put wire from the black (-) to the (-) output on your amp.
Posted on May 18, 2010
Can Isubstitute a car sub woofer to my home theater systerm
Probably. Most Car Subs Are 4 ohms. Most home subs are 8 ohms. If your amplifier is 4 ohm stable then yes. There will be no problem. Your kicker could have a model number something like c104. The last digit should be the ohms.
Jan 23, 2017 | Kicker Car Audio & Video
How do I properly wire 2 12 inch 40 cwr122 subs to a Kicker 12cx1200.1 mono amp
Need to know the resistance of the speakers you are wiring, are they 4 ohm or 8 ohm speakers? Is this for car or home audio? What resistance does the amp show it is capable of handling?
Oct 13, 2013 | Kicker CVR12 Car Subwoofer
How do I build a shallow box for my 8 inch Kicker Comp to fit on my motorcycle
It should be built out of mdf ,That it sounds decent, As for the size of the box figgure that out your self,
Nov 27, 2012 | Kicker Comp 05C88 8" Car Subwoofer
Kicker 8 inch l5 problem!
Possibly. Actually there are sub rings you can buy to convert a regular box over to one that will accept a square sub without cutting the whole out in your box to make it square. The airspace may be lacking a little bit.
May 20, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What are the specs on a kicker sub box for a challenger srt8
On a 8 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 11 liters, meaning that you will end up with a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 225mm high, x 225mm wide, x 225mm deep. Seal the box on the inside with silicone for better bass.
Oct 19, 2009 | Kicker Car Audio & Video
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
Kicker 05C104 Car Subwoofer Logo
48 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
