Question about Thermador CVS236 36" Cook 'n' Vent System Kitchen Hood
My thermador CVS36RB built in down draft fan quit working. For a while it would get stuck in the up position, but would eventually go down. Now nothing works.
2 Suggested Answers
  • 5 Answers
SOURCE: Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
Posted on Jan 07, 2009
How to change the switch on a thermador UCV36
Thermador Appliances ' Customer Support, Service, Repair ...
www.thermador.com/support
ThermadorThermador customer support is your appliance resource for FAQs, use & care videos, product registration, warranty information, service, repair and more.
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=63
ThermadorWe recommend that a Thermador authorized servicer change the seal ... refrigeration appliances, especially when the cooling function is switching on or off.
How do you install the up/down switch in a Thermador ...
www.shopyourway.com > Manage My Life > Questions
Get shopping advice from experts, friends and the community! I have a Thermadordowndraft vent model number RDDS30VRS that I need to replace switch part ...
Vent snorkel stuck in up position, fan works fine - Applian
Dec 21, 2015 | Thermador Kitchen Ranges
How do I fix an F34 error code on a single Thermador wall oven?
If the fan is blowing, then likely a sail switch problem. If switch ok, we see control board failures that cause this also. If need be, we can rebuild the boards for you. See
Limited supply of refrigerator boards for sale Used in Whirlpool...
Sep 15, 2015 | Thermador Ovens
Are there any online manuals for the Thermador cvs36rb, available?
If you go here http://www.abt.com/product/3627/Thermador-CVS36RB.html you can download installation and owners manuals in PDF format
Jul 09, 2011 | Microwave Ovens
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Can fan be lower when operating at full speed
Improper air flow was also my problem. The contractor did a terrible installation job. The duct work was incomplete at the transition piece (he used the under cabinet space as part of the duct) and did not seal the duct to the fan assembly. Both items were not readily visible. Once the duct was correctly installed, the unit works fine. Remember a down draft is never as good as an overhead vent.
Jan 02, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Nov 22, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Janitrol/Goodman GMP075-3 Draft Inducer Fan Won't come on
most forced draft fans are powered by 120 volts . close to the fan is usually a plug that unsnaps. create a call for heat after turning off to clear safetys and see if your getting 120 to fan on initial call for heat. if you are then fan draft motor is bad, usually sold as an entire assembly replace exact as it came out. sequence of operation is..... stat calls for heat via common and white wire to furnace , 24 volts. ......board sences call and sends 120 volts to forced draft ........ motor runs and creates pressure on proofing switch,....... switch closes 24 to board and tells it draft fan is on......... board then energizes ignitor,....... after ignitior glows gas valve is opened and burner lights ........ either ignitor or seperate sensor rod tells board the burner lit........ and a few minutes later the fan comes on and hot air is blown out. if a step is missed or doesn't proof the furnace either trys up to three times to light or locks out. turning off power usually resets safetys and it will resume attempts to lite normally.
Oct 25, 2008 | Heating & Cooling
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Thermador CVS236 36" Cook 'n' Vent System Kitchen Hood Logo
219 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
