Question about JVC RX-6040 Receiver
My JVC RX-9010 receiver powers up & after a couple of seconds there is a click & the unit powers back down. I have disconnected every line from the unit so the power cable is the only thing being plugged in. Is there a "button combination" to push that will give a self-diagnosis upon powering the unit up? If codes are displayed, is there a place to find out what the codes actually mean? Many Thanks!
  • 2 more comments
  • seagreg
    seagreg May 12, 2010
    I found how to run a self-diagnosis on the receiver & got the following (if this means anything to anybody):
    S000D
    2000120900
  • seagreg
    I found how to run a self-diagnosis on this receiver & got the following codes:
    S000D
    2000120900
    Does this mean anything to anyone? I am out of work so "just buying another AV is not an option.
    Thanks!
  • Eric Prince
    Eric Prince Feb 16, 2013
    were the resistors R916 and R915 changed? these are rated at 1/2 watts so should they be replaced with 5 watt resistors?
  • Martin Wong
    Martin Wong Nov 03, 2013
    The original resistors are of 2 Watts. I change for 10 watts. Voila.
  • 26 Answers
You ned change a couple of resistors of 10 ohms at 5 watts near the digital board (Optical inputs)
Posted on Aug 22, 2010
  • Eric Prince
    Eric Prince Feb 14, 2013
    what resistor number? exact location of resistor?
  • Eric Prince
    is it R915 and R916 ? these are rated at 1/2 watts so should they be replaced with 5 watt resistors ?
My RX-V2095 Yamaha receiver won't power up.
Wont power up, or stuck in "protect mode"? Unplug the unit & let it sit for a couple hours, then plug back in & listen for a "click" a turn (power supply relay energizing.) If no lights & no click, the first place to check is the mains fuse. If the unit is under warranty - take to an authorized facility & they will take care of it for you.
Oct 20, 2014 | Yamaha Rx-v2095 7ch Flagship Home Theater...
Receiver shutdown
change your power regulator it is leaky and there are some diodes around the regulator change them also check the caps and some of the resistors some also can be faulty.good luck.
Jun 07, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
My left channel in my JVC RX-305 isn't working...what do I do to fix it? When I either push the volume up or down it makes a clicking sound. It was working just fine last night. My right channel is...
Try swapping the speakers or just check the left connections WITH POWER OFF. Disconnect the left speaker completely and see if the clicking stops.
Sep 05, 2011 | JVC RX-618V Receiver
Around 4 second after power up the unit shuts down..
my jvc rx-8010v turns on and after 4 seconds it shuts down.
Jan 05, 2011 | JVC RX-8010V Receiver
Major power surge/outage & JVC won't stay on. Clicks on and starts to cycle, then shuts down. Fuse blown? Reset button somewhere? or trashed?
If appears "OVERLOAD" before turn off, you ned change a couple of resistors of 10 ohms at 5 watts near the digital board (Optical inputs)
Apr 19, 2010 | JVC RX-9010V Receiver
JVC RX-6042S shuts down after 5 seconds
It will be one of the transistors that regulate the lower volatges (5V, 12V...)
I ffixed mine. the heatsinking on those transistors is pathetic, and its no wonder they dont last.
Mine was the 5V circuit, which also supplies the DSP board. so if you are getting a DSP NG, that could be that as well.
Check Q1434 and Q1404. if one is faulty, it drags the other one down with it.
Good luck.
Dec 27, 2009 | JVC RX-6042 Receiver
JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
May 14, 2009 | JVC RX-6040 Receiver
Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Jan 27, 2008 | JVC RX-1028V Receiver
JVC receiver shows power, but won't turn on
Your receiver have a bad channel, maybe is a couple of damage
transistor.
Your need indentificate and change the transistors.
Dec 28, 2006 | JVC RX-9010V Receiver
JVC RX-6040 Receiver Logo
265 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
