Question about Sony Televison & Video
My Sony Bravia 32EX400 does not work with inverter when the light is off . Please solve the problem.
  • 178 Answers
This is a 2010 model, sounds like backlight failure, replace the panel on factory warranty.
Posted on May 13, 2010
Sony Bravia no sound no video?
its need tv up date soft ware please up date your tv
Jun 10, 2015 | Sony BRAVIA KDL32EX400 32" 1080p LCD TV...
Sony bravia 32ex400 5 time red light blink
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 25, 2014 | Sony Bravia Klv-32ex400 Multi-system Full...
How to repair? fault - backlight is on but no display, display is white.
T'Con board fault. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Jun 03, 2014 | Sony Bravia Klv-32ex400 Multi-system Full...
How to fix problem with power supply sony klv 32EX400 ,showing only 3.3v stby
Please specified problem,Check BackLight Inverter Board look for any burnout component,then look power supply,generally Power supply shows only 3.3 or 5v in standby condition,after initialize by control engine you may able to check several power rails.
May 13, 2014 | Sony Bravia KDL-32V4000 32 in. LCD TV
My bravia kdl52nx800 shuts down right after turning it on. flashing 6 times
Very common problem the 6 blinks is indicating an issue with the Inverter. Replacing the inverter should solve the issue. You should be able to get the Inverter from www.tvcircuitboards.com
Oct 27, 2012 | Sony KDL52NX800 52 inch BRAVIA 1080p LED...
Sony Bravia KDL 32EX400 stuck on channel one
It sounds that the main system memory IC has damaged. Before make it sure, just make a hard reset to this set, and check whether it helps you. To make it a hard reset, just unplug the AC cord from AC mains wall socket, and re-plug it back after 30 minutes or so.
If this do not help you, check and replace the main system memory IC.
Aug 22, 2012 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
T.V dosen't work with battery or inverter
The TV use 110V 60Hz sine wave AC, after rectified will be 156V DC, your inverter may be output 110V square wave AC, after rectified only 110V DC, it is too low for the TV work. except it can adjust to 155V.
May 18, 2010 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Televison & Video Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
