Question about D-Link DIR-300 Wireless Router
I can not access my dlink system configuration using 192.168.0.1
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Hi Thanks for your question. What you need to do is.
1. Click start and go to run 2. In run box put cmd 3. This should take you to the command prompt you need to type there ipconfig 4. You will be showed your network settings and your default getaway address is the address of your router 5. Type this address in your browser it should take you straight to your router site.
Good luck and please don't hesitate to ask more questions.
Posted on May 12, 2010
Dlinkap
http://support.dlink.com/emulators/wbr2310/lan.htm
Aug 06, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Dlink accesspoint doestnot connect with playstation3
The Dlink wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Dlink modem's wireless settings so it can communicate with the wireless modem.
To configure the PS3 please follow these steps :-
1. Power up the PS3 and login then Select Network Settings and
press X
2. Select Easy then press > button
3. Select Wireless then press > button
4. Select Scan then press > button
5. Select the wireless modem you want to use, then press X button
6. Confirm the SSID for the wireless modem then press > button
7. Select the security settings (ie WAP, WPA - this is the in the wireless modem settings) then press > button
If there is no encryption I suggest you enable the encryption on the wireless modem, use passphrase to generate the encryption key.
Write down this encryption key, you will need this key for your computers and PS3.
8. Enter the WEP or WPA encryption key (from the wireless modem) then press > button
9. Check the settings then press X button
Dec 23, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Configuration dap 1150
You cannot configure the DLink by the URL address http://dlinkap?
You connect a LAN cable from your computer to the DLink.
Then open Internet Explorer and enter the URL http://192.168.0.1
the default login = admin
the PW is blank (just press Enter)
You can now configure the DLink.
Sep 28, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Systems cant ping each other
can u ping ur gateway? and the router too? then make sure all the system workgroup have the same name. use the same IP for all that is automatic use automatic for all, and if manual setting use manual setting for all.
Jun 17, 2009 | Linksys Business Series WAP4400N...
Unable to access DLink WBR 2310 Configuration page
At the back of the router is a tiny pinhole. Using a pen try to press it for 15 secs and try to access the page using the 192.168.0.1
Jan 02, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless access point connecting to router...
The question is how do you want to cable the netgear and what do you want to do with it.
If you cable a lan port of the DLink to the Netgear WAN port you will have two subnets that must be addressed differently. Opening up and forwarding the ports for XBox could be difficult.
I believe cabling the Netgear as an access point makes more sense. CONFIGURE THE NETGEAR BEFORE CABLING. This is achieved by wiring a lan port on the DLINK to a lan port on the netgear and ignoring the wan port on the netgear. This will involve configuring several router items that should be completed before the devices are cabled together. You will need to remember the Netgear's new network address and probably use a static IP address from a computer to configure it back into being a router after these changes, if required. Or reset the configuration to factory default following the users guide.
First the Netgear needs DHCP turned off as it will be part of the DLink's network and not a separate subnet - the DLink will perform the DHCP services.
Second the LAN side of the Netgear will need a static IP address in the DLink's network. This is where it may get tricky for you. Verify the DLink has an IP Address like 192.168.0.1 and a subnet mask like 255.255.255.0. That means all IP Addresses in your network start 192.168.0.??? where ??? is unique for your network. Verify your DLink router has a set of addresses reserved in the DHCP setup for dynamic address assignment these addresses like 192.168.0.100 to 192.168.0.199. If the above is true or with the information you extract from you DLink router you need to determine where you can create static IP addresses -- in the above case 192.168.0.2 to 192.168.0.99 are available. You need to assign one of those like 192.168.0.2 to the LAN side of the NetGear Router. You will probably want to assign another to the XBox == like 192.168.0.20. You will probably need to deal with opening ports or placing the XBox into the DMZ of the DLINK router which will require a static IP Address.
Now cable the devices
When considering the XBox Configuration below the DLink is the router that must be configured to allow the open ports or DMZ access to the Xbox == the netgear is not functioning as a router in this configuration.
Check out the following links on XBox Configuration if required.
The second link may be the best to start with.
The generic connection and configuration document
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
This is a good description of possible router2.gif options.
http://www.ianarchbold.com/xboxlive/index.html
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 27, 2007 | NetGear MR314 (MR314NA) Wireless Router
How to Configure D-link dwl-510 WiFi Card
To configure your linksys, access point, we need more information, the ipaddress oif your dlink router and the wireless settings on your dlink router..,
for more informations, check this link http:kb.linksys.com
for more details contact linksys; 18005465797
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
D-Link DIR-300 Wireless Router Logo
197 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
