Question about GE Advantium 120 Convection/Microwave Oven
120 Advantium Does this kit solve the problem or is it just a quick fix that disables the safety feature?
I have installed the kit that the GE service man stated would fix the problem as I documented in a solution on this site under my username of loyola1986. It changed a few parts allowing more ventilation of the thermostat. We have not used it enough yet to verify that the fix works. I will try and post something when I am confident the fix works.
Posted on Apr 25, 2008
I have not installed it yet. I plan on doing it this weekend. My lovely better half is eager to get back to using the speed cook. She loves that part of it. Check back in a week and if I have not posted anything, send a request to me again. Sorry I can't tell you right now and I don't want to just say yes it will fix it without really knowing.
Posted on Mar 29, 2008
  • loyola1986 Sep 18, 2008
    Since installing the TCO repair Kit, we have not had any further power shut off. This kit is not widely known for this particular model (120). It has been widely used for the other model. So, a service technician may look at your 120 and still just replace the TCO or Thermostat, which I did twice and didn't resolve the problem. Again the kit resolved our problem.
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
Oct 21, 2014 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
No power, i have power to the outlet but nothing on the unit works.Is there a fuse?
remove the cover ... look on the floor of the unit near where the cord enters the cabinet.
Oct 12, 2009 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
Interior light always on Ge advantium 120
I bet by now your microwave is no longer working....did the bottom or top "hook" finally break off? I found that mine had cracked and started coming loose and so when it closed it was no placing enough pressure on the internal safety switch that tells the oven the door is shut. I was able to use a sturdy plastic glue to solve the problem but finally after about 2 years of fixing it I can no longer get it to bond. Now, I'm looking for a new part. Who makes a product this expensive with plastic parts!!?!??!?!? So frustrating.
Apr 13, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Opinion
I have had an Advantium for about 3 or 4 yrs and would use nothing else! When this one wears out I will buy another one! I hardly ever use my regular oven any more! Hope this helps.
Feb 02, 2009 | GE Advantium 120 Convection/Microwave Oven
Broken bottom latch on GE Advantium 120
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Replacing the cavity light on the g e advantiom zsc 1001
The bulb is a halogen type and there is a service kit that slighty changes the way it is mounted. It is not easy to get to from the top unless you do it for a living. Call GE Factory Service for the kit and a nice smiling technician to come out and take care of it. It may still be under warranty. 1-800-432-2737
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium Power Out
Same Problem - baking when all power appears to go out - but the AC power is plugged in and it is good: This is a known manufacture defect for the Advantium 120 model SCA1000. But, don't expect Sears or GE to take care of you. Short version: A Thermister that cost under $1.00 to manufacture and is known to be defective in this and other products needs replaced. But, the schematic, the GE Repair Center, and local GE repair center don't document things right and don't have the part. I won't buy GE again since they can't control the manufacture of fire safety standards in the Korean plants. This part will be defective after about 3 3/4 years of being plugged into the wall. So much for your optional 3 year warranty! Read the entier solution before trying this at home: 1. Remove the button front panel where the display is at. The ribbon cables to the front panel will allow room to peer inside. There is an envelope taped to the side with the schematic. 2 On the Schmatic Diagram (not the wiring diagram) on the bottom see CN6 - with two thermistor. Now look at your actual wiring. Guess what! GE did not even put the right wiring diagram in your maicrowave! GE shows a 3 wire device. Actually you will find 2 different 2 wire devices! Thanks GE, I took the part and the schemetic to an Authorized GE repir parts store. They checked with the GE parts manager in Dallas. After paying the GE shop $49.87 for the part order, after 6 follow up calls and 3 weeks, they send the wrong part on the schematic, not the part that I brought in that is actually in the oven. 3. The part that is bad in your oven is a thermister that cost about $0.14 to make. There are two of them. There is two wires that attach to them. If your unit overheats, it shuts down the power for safety. What happed is that one of the two thermisters is opened (defective). They are screwed on to the service to detect heat. The numbers on the can are PW-2R (PWC PW-2). One of mine measures about 44 ohms, the other exact one is open (infinate resistance). It is two wires attached to a round cylinder about 3/8" wide - a bracket holds it against a flat surface with a single phillips screw. Its purpose is to detect heat, if things get too hot, it switches from on to off. When they go bad - it stays in the off position. The effect looks as if you don't have your microwave plugged into the wall. 4. Ordering the PW-2R. GE has no record of them. Thanks again GE! HP laser Printers used them on one model. This little part caused all of the printers to go bad. From an internet article, it appears that HP Printers no longer use this part. In the case of GE, it is my opinion that they got the microwave safety approved then switched out parts for manufacturing. Where is Consumer Reports when you need them? 5. I am still searching the Internet for a substitute part. One Sears repair person quickly (and unofficially) told me that it would be the Thermister, a known problem before I started. This is my worry: If the part is not available, and repair persons are making quick fixes (for about $100), that they are simply cutting and tying the connector together. In otherwords, they are taking out the safety feature rather than replacing the safety part. If I find the part, I will post it on here. But, after a couple of hours of searching, and checking with various part shops it does not look too good. It does not take much searching on the Internet to see that the GE Advantium is widely known for poor manufacturing standards and about a 4 year life-cycle. When one considers what it cost... it appears to be rated as a bad investment to trust GE applicances. By the way - the schematic and other parts indicate it is manufactured in Korea.
May 16, 2007 | GE Advantium 120 Convection/Microwave Oven
Does not work after speedcooking bacon.
Most repair warranties are only 30-90 days, but you might consider asking the servicer if they'll cover it. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your actual model number (like SCA1000DBB03, not Advantium 120) here: http://tinyurl.com/gv383 That part is the thermal cutout (TCO) or thermal fuse. It's reference number 1430 on the first diagram listed there.
May 07, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
85 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
