Question about Echo CS400 18" Chain Saw
My Echo CS starts fine but then will not accelerate. Sometimes, after it's warm, it will work OK, but more often, it acts as if the chain lock is engaged and almost wants to stall as the throttle is pulled. It just wants to idle...... What gives??
    Brigadier General:
  • 4,088 Answers
Can the chain be pulled by hand fairly easily? Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Try turning the H jet needle CCW about 1/8 turn--the engine should 4-stroke when running free at speed, but 2-stroke when cutting. Hope this helps!
Posted on Jul 23, 2010
How to replace clutch spring on a echo 650 chain saw?
id replace the entire clutch as if spring came out then therese got to be a reason
Mar 01, 2015 | Echo Cs-650evl Cs 650evl Chain Saw...
How to reassemble chain brake on an Echo CS-350T that jammed and was pulled apart by someone else?
From what I see you will need assemble thing leaving the main spring and brake cover off. Before attempting to put the main back in install a clutch drum inside the brake band. Then you slip on the main spring and pry the end on with a flat blade screw driver. Now install in the cover for the spring and brake. Reset the chain brake and remove the drum.
Now install the chain brake on the saw and test. Do not trip the chain brake without the clutch drum in place. If these are anything like the Husqvarna version after they get worn they will get where it is nearly impossible to reset.
Echo CS 350T Chainsaw CS350T Parts Diagram Page 7
Jan 12, 2015 | Echo Garden
Air vent in my echo 3500 cs chain saw
Take a fine bit drill and gently turn it through the hole
Apr 07, 2014 | Garden
Toyota echo shifting up problem
i have a 2003 echo and it has done the same thing since i got it .bought it with 29 k i now have 147 k never did anything .i did ask and got 2 answers .1 was the coolant sensor under the intake manifold needs to be changed and from what ive heard it is a lot of work . the other was from a tech and he said it was to let the engine heat up to prevent the build up of sludge in the engine which i think is a crock of ,,,.any way ihaven,t done anything in over 100k and no ill effects.i will admit sometimes it does annoy me but not enough to act yet .
Apr 02, 2012 | 2003 Toyota ECHO
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Echo cs-370 chainsaw wont start. running fine the day before. good spark. fuel wet at muffler. plug always wet.
Check air filter- is it clean?
Some plugs are without cilinder ok but if in place dont work. cahange the spark plug.
Mar 17, 2011 | Echo Garden
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Yes I have a echo CS-3450 type 1-E and have to work the throttle just to keep it running.changed the fuel filter,sparkplug,gas ratio 40:1
Check the fuel lines for decay or other damage. Make sure the muffler is not plugged. If the jet screws have slot heads, turn the H jet screw CCW somewhat until the engine 4-strokes at speed, but immediately 2-strokes when cutting. If the engine lags behind the throttle when accelerating, turn the L jet screw CCW about 1/8 to 1/4 turn. Hope this helps!
Oct 30, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
How to install bar and chain on cs 310 echo
A CS-310 OM follows:
http://www.echo-usa.com/pdf/documentation/CS310es1112_042310.pdf
There is a very good, model specific, procedure beginning on page 12.
There are 2 listed based on serial number I think, you can download the other and an IPL here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 21, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo CS400 18" Chain Saw Logo
488 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
