Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error 2 paper out but not
I keep getting a pop up saying the paper is out and there is plenty of paper it keeps saying E 2 it will pull the paper in just a little then stop and flash E 2 and ill get a pop ups aying paper is out
    Scholar:
  • 97 Answers
Does that printer feed from two ends -- a tray and a feeder at the back? If so, make sure your program is set up to draw the paper from the correct tray, or else put your paper in on the other side.
Posted on May 12, 2010
Had paper jam which have cleared. Getting support code 6001 saying turn off and restart which we have done but still keeps coming up with same error
The 6001 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
Aug 24, 2016 | Office Equipment & Supplies
When I try to insert CD in to Dennon S3500 it wont insert, it keeps saying Disk Error
if this is a CD that gets plenty of play, (take a dry paper towel, going in one direction in a circular motion wipe the CD)
Aug 29, 2010 | Denon DN-S3500
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
Printed 47 pages, paper for page 48 started to feed incorrectly & was yanked out. However, LCD keeps saying paper jam even though entire paper was retrieved. Turning machine off, on, examined for any...
More likely especially if the paper was pulled out backwards, that the paper sensor just before the platen roller is bent or broken. When you pull paper back up thru the feeder it gets caught on this sensor tab and it gets bent, holding it up just like a paper scrap would. If it's broken or you can't locate it to bend it straight, you will need a shop to repair your printer.
Dec 31, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper want go in to print
The reason why it keeps saying this is cuz you paper feed tire needs replacing. Now i am not sure based on the cost of this unit if it would be worth to have this repaired but, this is what is causing this error.
Jul 24, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error message says "no paper" but there is plenty of paper
I had this same problem,
Here's what did it for me:
1)Power off the machine
2)As you hold the 'Menu' Key down, turn the power back on.
(this will take you to maintenance mode)
3) Press 91 to do a parameter reset
4) Press 99 to exit maintenance mode.
I hope this helps you as it did me.
Mar 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Brother HL 5150D not printing unless I keep pressing Go
its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
Jan 08, 2009 | Brother HL 5150D Laser Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
My printer is eating my paper
Hi
I had exactly the same problem and had to stop my flatmate trashing the thing! Try buying the cheapest, nastiest supermarket printer paper you can find! Works great in mine...
cas
Jan 07, 2008 | HP PSC 1510 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
78 people viewed this question
old marine
old marine
