Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F1 code on display and machines will not turn off
  • Fisher and P... Master
  • 12,061 Answers
Take out the bottom draw, mop up the water, then remove the black cover protecting the PCB and sensors, Now five minutes with the hairdryer on a very low heat, and hey presto, no problems, I think the problem stems from cups on the foldown trays, not allowing the lid to seal properly.
Posted on May 12, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Runs 20 sec stops reads F1E5
    Error Code/Message - Oven - F1 Error Code - F1 E5
    Control displaying F1 E5:
    There may be a problem with the Oven Control, or the associated wiring.
    Power unit down by turning off the circuit breaker(s) for one (1) minute.
    Power unit up by turning on the circuit breaker(s).
    Monitor the oven for one (1) minute to ensure the error code does not display again.
    Verify oven operation.
    Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
    F1 code for oven
    I found this information related to a different model of the Vacmaster:
    If you see F1 displayed on the LED screen and the machine will not function, make sure the lid is open and turn the power off. Turn the machine back on and it should return to working order.
    May 12, 2014 | Vacmaster Vacuums
    F1 PROBLEM ON VACMASTER VP540?
    Mar 25, 2013 | Vacmaster Vacuum Pack Machines: VP540C...
    F1 error code
    Call Whirlpool at 800-688-9900.
    Let them know you have a Bravos or Oasis washer and you are getting a F1 error code.
    They will send someone out to replace the controller board for free!
    If not, here is a link to the control board you need.
    Oct 16, 2012 | Maytag Bravos Top Load Washer
    I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to ''turn switch off and on''. What could be wrong?
    When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
    - E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
    - E732-8888 can be displayed when a different scanner is connected to this machine.
    1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable).
    2. Turn ON the main power switch.
    3. Change the setting values of the following service mode items.
    - Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'.
    - Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'.
    Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1.
    - Color Image Reader-E1: Platen cover model
    - Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1)
    - Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180)
    4. Turn OFF the main power switch, and connect the DDI cable.
    5. Turn the main power switch ON.
    Note: How to turn OFF the main power switch.
    When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine.
    1. Hold down the control panel switch for 3 sec or more.
    2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.)
    3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
    Nov 17, 2009 | Canon Office Equipment & Supplies
    I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to "turn switch off and on". What could be wrong?
    Nov 17, 2009 | Canon ImageRunner 2220N Copier
    Sharp AR-405 error code F1-15
    Hello sir; this error code means " elevator motor "problem inside the finisher,check it out is something stuck the motor. or you have to replace one.
    Feb 16, 2009 | Sharp AR-M205 Copier
    F1 error
    I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
    Nov 13, 2008 | Maytag Ovens
    Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
    231 people viewed this question
    Top Fisher and Paykel Dishwashers Experts
    Brian Coughlan
    marley mcelhinney
    Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
