Question about Whirlpool LSR6334LQ Top Load Washer
Help! The agitator in our Whirlpool LA5558XS Washer is not working. It was recently delivered (given) to us. It worked fine prior to the move...
  • 183 Answers
SOURCE: Whirlpool Washer LSR8233EQO
either motor faulty or if mtor is running then the flexibla coupling between the gearbox and the motor is faulty. Regards Advisor
Posted on Aug 22, 2007
philbran
  • 242 Answers
SOURCE: Whirlpool Washer does not spin or agitate.
The motor coupling has broke , it is a small plastic rubber piece you can see under the unit that connects the motor to the gear case. very common problem about $120.00-150.00 to have repaired or $20.00 or so for you to replace. they are not simple but not to difficult to do.
Let me know if I can help or answer any other questions.
Posted on Apr 14, 2009
SolutionGuy
  • 331 Answers
SOURCE: Agitator does minimal agitation
Hi Omni,
The Agitator "dogs"/cams have given up the ghost and need to be replaced. Access to them is easy. Before starting the repair, have this part in hand.
Here's a tool list;
1.) small flat screwdriver (to remove the top part of the agitator)
2.) 3/8" ratchet
3.) 8" X 3/8" extension (for the ratchet)
4.) 7/16" socket
Take a gander at this pic... you'll be going after #10 'cause that's the problem.
All you gotta do is remove the top parts from the agitator to access it. See #2 in the diagram? That's the bolt holding the agitator to the transmission shaft. Remove that, then lift the whole agitator out of the tub. Now place the agitator on the floor and put both of your feet on the base. Now lift the agitator (#3) off the base (#4). Place one of your hands into the opening of the top of the agitator (to hold the cam (#9) in place) then turn the agitator over. The cam will slide right out.
Now you'll see the cam "dogs"... little white curved plastic doo-hickeys. All you gotta do now is install the new cam assy. and rebuild the agitator! Cool, huh? All it takes is about $15 bucks in parts and ~20 minutes.
Let me know if you have further questions. And don't forget to rate my solution as "FixYa"! Thanks, BB
  • 121 Answers
SOURCE: whirlpool ult care II (plus) washer, agitator makes noise
yes, sounds like your agitator dogs are broken, four beige teeth inside top of agitator part only roughly 4.99 to 29.99 and labor 65.00 - 95 labor depending were u live and who u use. thank you
allbrandsappliancerepair.com
Posted on Sep 23, 2009
washdryman
  • 154 Answers
SOURCE: Whirlpool /Roper washer won't drain or agitate.
LID CONTROL SWITCH BAD
Posted on Feb 07, 2010
Whirlpool model la5558xs agitator won't turn during wash mode
Replace the agitator dogs. Here is the part to order.
There is a video on that parts page to show you how to replace them.
Dec 03, 2012 | Whirlpool 3.2 cu. ft. Plus Washer
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
Just recently moved & had washer in storage for about 4 months during summer. The washer will add necessary water then just as the wash cycle is about to start it goes from 38 minutes to 4 minutes on...
does it drain the water??? most coommon prob with this unit is faulty pump/ item in pump preventing proper drain, if it thinks theres water in or too much water in it will automatically try to drain and do nothin else, drain motor might have siezed form sitting as well, that why yo ned to check to see if water is actually draining out.
Oct 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Slow spinning agitator with knocking sound
agitator dogs. take them out and replace.
Feb 28, 2009 | Whirlpool Washing Machines
Agitator runs at a very slow pace.
it sounds like the belt may be stretched not allowing it to agitate as it should
Jan 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer Mod# TWAS750PQO, Ser# CR3520005
is it possible that the washer was overloaded? if so the agitator has little plastic "gears" that move the agitator one way only, they could have made the sound.
you can also check under the washer to see if anything (like a coat-hanger or something) is interfering with moving parts of the washer
Jun 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kitchenaid top load wahing machine # YKAWE870BW1
You need to replace little gears called agitator dogs. Once agitator is removed pull top half of it off. Exposes the dog carrier.
Nov 28, 2007 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool LSR6334LQ Top Load Washer Logo
1,139 people viewed this question
Dan Webster
Dan Webster
Sal De
