Question about Toshiba Satellite A505S6015 16" Notebook PC Quantum Black (PSAT6U00H001)
I have a toshiba A505 intel3 processor laptop and cant figure out how to change the mouse sensitivity cause it clicks on and off stuff with out even touching the pad and turns off programs
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sniper:
  • 62 Answers
Go to Control Panel, then Mouse, under Pointer option tab, you can adjust the motion speed.
CompQ
Posted on May 12, 2010
  • 560 Answers
Click On start , then control panel , and double click on touchpad settings to change all of your options and settings .
Toshiba a505-s6960 won't turn on
You should better go to the service center of Toshiba for the best solutions. The incident may have caused major issues to your laptop.
Regards, Mrityunjay.
Jun 19, 2012 | Toshiba Satellite A505-S6960 Core 2 Duo...
Can I use a Toshiba recovery disk for A210 series if I have an A505 series? They are both Windows Vista
That is about the only thing thew same about them other than the name Toshiba. The A505 is an Intel Processor, the A210 has an AMD processor. They have completely different video graphics chipsets, audio, and LAN configurations, Assuming that the A210 disc will load in the A505, you would not get proper video, audio or LAN drivers. Recovery disks are made for the machine they are bundled with. You can try, but don't be surprised if your result is less than optimal.
Jan 06, 2012 | Toshiba Satellite A505-S6034 Laptop...
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
I have a TOSHIBA NB100.The mouse pad is too sensitive .I can even move the cursor hovering my finger above it without touching the pad .I thinlk it causes words and letters to come out as a jumble. Is...
control panel----Mouse----Should bring you to a screen with several tabs at the top-----pointer options tab---Select a pointer speed this should slow down the mouse movement----then go to the first tab (touchpad) and you can change the touchpad sensitivity. Hope this helps
Jan 07, 2011 | Computers & Internet
Hyow do I change screen brightness?
Well reguraly you use funtion key (Fn)+ a key with a sun full for more bright and a sun empty for bright . Remenber press Fn and then the other repeatly.mastericpr08_2.jpg
Dec 23, 2010 | Toshiba Satellite A505-S6970 Notebook
When typing an email the keys skip back to the
When I have seen this happen, the touch pad was set overly sensitive. When you are typing, your palm may be moving the cursor. If this happens at other times, then this can be corrected in the control panel. Go there and click on touch pad. It will have settings to set the sensitivity for the mouse pad, speed, double click/single, etc. You can change the settings to be more suited to your hands.
FYI: Older laptops were more susceptible to touchpad errors and I have even seen the area on either side of the touchpad to cause the mouse cursor to move and jump.
Good Luck
Dec 16, 2009 | Toshiba Computers & Internet
Mouse becomes jumpey and wont grab scroll bars
do you have touchpad drivers installed....if you do...go to control panel - mouse - properties and change the settings
Nov 04, 2009 | Toshiba Satellite A105 Notebook
I have model A355-S6935 its a new unit. My problem is when typing the type skips out of the sentence into the lines already typed. Is this a common problem as it causes major rework and is extremely...
easy, your touching your mouse pad (square you touch to move the mouse), you can turn it off and use a regular mouse, turn off the laptop, plug in a mouse, windows will automatically detect it.
On every Toshiba notebook Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties.
Make changes to the mouse and mouse pointers in the Mouse Control Panel. To open Mouse, click Start, click Control Panel, click Printers and Other Hardware, and then click Mouse.
Good luck,
Mr.Fix-it-guy
Aug 13, 2009 | Toshiba Satellite A355-S6935 Laptop
Mouse Setting Problems
First right click on my computer then properties then system restore should be at the top
it's there somewhere try and restore your pc to an earlier date when you know it worked.
Then restart your pc
If that did't help I would definitely do a virus scan
Jan 15, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A505S6015 16" Notebook PC  Quantum Black (PSAT6U00H001) Logo
129 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
