Question about Dishwashers
Water dont enter dishwasher - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
Dishwasherwater dont enter dishwasher - 2_bing.gif Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on May 12, 2010
Water enters dishwasher,the unit seems to go on hold, then it will drain. Nothing else works as far as the washing cycle or any thing else.
this could be that the main pump id defective, once water enters the main pump does all the work to throw the water around and clean, once that is done the water is drained etc.
so when you dont hear anything this indicates that the main pump is not running.
supect this part first.
I hope this was useful
Mar 14, 2011 | Bosch SHU9925UC Built-in Dishwasher
Water will not enter dishwasher
check power is on
ensure water is connected and on.
suspect water inlet valve, if this part is defective or not geting power it will not open and let in water. these parts a designed this way so if they fail you dont get a flood.
Mar 02, 2011 | Bosch SHU9925UC Built-in Dishwasher
No water enters the dishwasher when its turned on
heatman101
May 23, 2010 | Bosch SHV46C03 Built-in Dishwasher
Bosch dishwasher SHU9926UC
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Top spray arm not connected to anything so dishes dont wash properly
as long as you have a spout mounted in the middle of the top basket, everything is fine , water will spray from top nozzel (mounted in ceiling of dishwasher) into spout entering spray arm.
May 01, 2009 | Dishwashers
Dishwasher not emptying the water out
Check pressure from power supply, check if the inlet valve is faulty or obsstructed.
If you find no problem, you may need to replace the pump.
If you enter model number here , you can find parts and diagrams.
Apr 06, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
