Question about Craftsman 25cc Gas Line Trimmer
Engine dies when pulling throttle. - Craftsman 25cc Gas Line Trimmer
    Scholar:
  • 110 Answers
Check that the muffler isn't partially blocked. If not, may need a new diaphragm in the carb.
Posted on May 12, 2010
I had just got on the highway in my 2001 GMC Yukon Denali when all the sudden it would not accelerate Once I pulled over and tried to restart the truck though it would start it would not accelerate...
It sounds like a Mass Air Flow sensor or a Throttle Position sensor.BUT you will have to get a scan and find out what the check engine light is all about and related engine codes to attempt to fix this. This would be my first step. Good luck
Apr 28, 2014 | Cars & Trucks
Cub cadet cc4125 dies when throttle is advanced
Hi, the carby needs to be stripped down an all jets blown out with compressed air. Also check that fuel is flowing to the carby, do this by pulling the fuel hose off the carby and cranking the engine. Regards Phil.
Jun 02, 2012 | Garden
My Ryobi blower starts just fine. I let it run for a minute to warm up and when i pull the throttle it starts blowing ; however, if i pull full throttle the engine bogs down and will eventually die. I have...
this sounds like a carb problem one that needs porfessional help take it to your small engine shop be careful as to not go over the valvue of the blower on repair and parts have them to give you a quote first
Jul 21, 2011 | Garden
Engine dies at idle. Engine sometimes sticks at 1500 rpm's. Engine always starts right up after engine dies. Maybe air regulator valve?
Pull air intake plentum off. Make sure that the throttle body butterfly is clean. If dirty you can get throttle body cleaner at Wal mart and local parts store. If the car does not have a throttle cable, it may be electronic working on a sensor. If so you have an electronic issue.
May 14, 2011 | 2001 Mercury Sable
Saw starts then dies. Changed fuel ine soaked carb
Check the fuel filter, air cleaner and muffler for plugging. Was the carburetor disassembled when soaked and did you use compressed air to blow out all passages? If the carburetor jet screws have been moved, preset them as follows: Turn both H and L screws CW to stops (lightly), then back out CCW each screw 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine speeds up somewhat but 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that chain stops turning, but the engine continues to run. Hope this helps!
Mar 30, 2010 | Garden
Trimmer dies when you apply throttle
Sounds like it might be getting to much gas. What position is the choke in during all of this? If you're giving it throttle it may be flooding itself out.
Aug 26, 2009 | Garden
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
99 CBR will start but wont run
did you check the fuel filter and fuel supply?
Jun 14, 2009 | 2001 Yamaha V Star 1100 Classic
Lumina Starting/Dying Problem
this could be one of the two things that I am thinking it is...it is either the throttle position sensor or it si the fuel pump getting too hot and cooling off slightly enough to restart the engine. Both are related but separate systems. The throttle position sensor is on the side of the throttle body and it merely tells the computer where the throttle plate is in the throttle body to create the proper fuel mixture for the injectors. The fule pump ios loccated insid eof the fuel tank it either runs or it doesnt usually. If it gets hot it is about to go completely out all together.
Aug 08, 2008 | 1991 Chevrolet Lumina
Craftsman 25cc Gas Line Trimmer Logo
283 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
