Question about Acer Aspire X1200-B1601A PC Desktop
Broken SATA Connector on Motherboard
The computer is an Acer x1200 (-B1601-A) desktop, running Vista Home Premium.
The connector on the motherboard where the SATA hard drive cable connects is broken.
Trying to find out is there is a fix or an alternate way around this problem, besides replacing the motherboard.
Can another connector be bought? Is there another SATA hard drive connector on the motherboard that can be used, possibly one for an additional hard drive? Could an SATA interface card be used, and bypass
the motherboard connector entirely?
Any help is greatly appreciated! Thank you!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
SATA connector can be replaced if a local technician should have any old damaged mother board with him and if he is ready to fix it on *********** board. you will have to find it by going to the different repair shop if they are available.there is no alternate solution to this problem as there is only one connector on the mother board. if some repair store agrees to do it for you then it could be done or else you will have to get the motherboard replaced.
Posted on May 13, 2010
Acer aspire x1200 - Will not turn on. no power at all
Had this computer to fix and it ended up needing a new CPU in order for it to come on! Tried everything before this and what clued me in was unplugging the 4-pin molex from the motherboard and seeing all the fans spin continually with just the bigger 24pin connector in there. That 4-pin connector powers the processor so that was it! Change out that processor.
Leaving my solution here for any others that may come by.
Feb 04, 2012 | Acer Aspire X1200 Desktop PC - Athlon X2...
NO POWER COMING ON
The Acer Aspire E500 Desktop PC uses an Acer MBP2207024 motherboard,
http://www.ascendtech.us/acer-aspire-e500-mbp2207024-motherboard_i_mbacembp2207024.aspx
I'll be referring back to the photos of the motherboard, at the bottom of the page of the above link.
Start with the power cables coming from the Power Supply, to the motherboard.
1) 24-pin ATX main power cable, and corresponding connector on motherboard:
Middle and bottom photo. Look at the top left side. There is a whitish long connector, with 24 socket holes in it, on the motherboard.
Here is an average example of the power cable, and the connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[Note* Color of connectors does Not matter ]
2) 4-pin ATX +12 Volt power cable:
It's hard to see in the photos. Go to the bottom photo.
From the left side; look at the purple Keyboard port, and green Mouse port.
Go to the right to the blue VGA port. (15 socket holes. 3 rows of 5)
Now go to the stack of 3 ports to the right of the blue VGA port.
Two USB, then a Firewire port on top. Right behind this stack, is the square 4-socket hole, whitish 4-pin ATX +12 Volt connector.
Average example of motherboard connector, and corresponding power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Note that on the male power cable connector, for the 24-pin power cable, and the 4-pin power cable, there is a Lock.
Shown more visibly in the middle photo of the above link.
This Lock acts like a see-saw on a playground. The top is squeezed in, and this action releases the hook at the bottom end, away from the tab on the female motherboard connector.
To ensure that these power cables are plugged in tight, the Lock needs to be in the lock position, over the tab on the female motherboard connector.
This power cable is power for the Processor.
That's it for the motherboard.
There should also be a SATA power cable coming from the Power Supply, to the SATA harddrive.
Average example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note*
There are two cables going to a SATA harddrive. The SATA power cable has the longer connector. It has 15 pins. Note that there is also an L shape on the inside of the connector. Lines up with the L shape on the harddrive.
The other cable is a Data cable. (information cable)
It has 7 pins, and is the shorter of the two.
Average example of a SATA data cable, and corresponding connectors on a motherboard,
http://en.wikipedia.org/wiki/SATA
Look at the photos to the top/right. The top photo shows an average SATA data cable. (Color does Not matter)
The photo also shows a Straight connector. This style of connector is usually used to plug into the motherboard. (Sometimes for SATA optical drives, also)
An Elbow shaped connector is usually used on the Harddrive side.
[ NOTE*
This is a 4-pin standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Shown connected to an older IDE (PATA) harddrive. It is also used on optical drives, and to computer case fans sometimes.
Point:
IF, your SATA harddrive has a provision on the back for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable.
Otherwise the SATA harddrive will BURN up.
May not happen immediately, but I assure you it will happen.
In the middle and bottom photos on the Ascendtech link, the SATA headers (Connectors) on the motherboard, are Orange, and at the Top/Right.
There are 4 of them.
The beauty of SATA:
Next to the SATA headers on the motherboard will be silkscreened a figure. SATA0, SATA1, SATA2, and SATA3.
Or it may have SATA1, SATA2, SATA3, and SATA4.
A harddrive should plug into SATA0, or SATA1.
HOWEVER, the beauty of SATA, is that you can plug the harddrive into ANY of the four SATA connectors on the motherboard, and BIOS will find it.
The plastic front of your computer is the Front Panel.
The rectangular block of plastic with pins sticking up out of it, on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Sometimes abbreviated as F_PANEL, or FP1, or PANEL_1.
Looking at the Top motherboard photo, it is the blue rectangular connector, at the Bottom corner.
In the Bottom motherboard photo, it is all the way to the Bottom/Right corner.
(Middle photo all the way to the right corner)
The CPU Fan, (Central Processing Unit, or also known as Microprocessor, or Processor for short), cable connects to the small 3-pin whitish connector, that is towards the top of the motherboard, and above the 24-pin ATX main power cable connector.
The System Fan, (SYS_FAN), or computer case fan, connects to the small 3-pin connector to the Right, of the 4-pin ATX +12 Volt connector, on the motherboard.
Front Panel header pinout to follow in a Comment.
Regards,
joecoolvette
Jan 21, 2012 | Acer Aspire E500 PC Desktop
After upgrading my acer x1200 to windows 7 pro 64 bit from vista home premium 64 bit the ethernet will not detect a cable
Here you go: http://global-download.acer.com/GDFiles/Driver/Chipset/Chipset_NVIDIA_1.81_Vistax64_A.zip?acerid=633819402516909459&Step1=DESKTOP&Step2=ASPIRE&Step3=ASPIRE%20X1200&OS=ALL&LC=en&BC=ACER&SC=PA_7. From this download unzip and install the LAN drivers then it should properly detect your cable.
May 14, 2011 | Acer Aspire X1200-B1601A PC Desktop
Acer Aspire AX1200-B1792A AMD Athlon X2 4850e Dual Core Processor Microsoft® Windows® Vista Home Premium 64-bit, 4.0GB DDR2 320GB HDD. And i can't make any Windows Update since the problem...
Your operating system is corupted. you need to install a new one.
Your computer has the right specifications for vista though i would recommend Windows 7.
It is a much better Operating system
Dec 26, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
I am trying to install a gdr-8164b drive in my inspiron 531 but the connectors are different. How would i go about this, is there an adapter that is available?
your drive is an LG gdr-8164b and is a IDE your computer is using for SATA drive which is different you need to change your drive to a SATA or get a PCI with a IDE
Sep 10, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
New acer 1641 freezes up after inserting wireless card
HI,
SOME PLUG AND PLAY DEVICES ARE NOT COMPATIBLE WITH VISTA EVEN SOMETIMES IT SAY'S THEY ARE CONTACT THE MANUFACTURER FOR AND POSSIBLE DRIVERS THAT WILL WORK WITH VISTA.
Feb 07, 2009 | Acer Aspire M1641-U1521A PC Desktop
Acer Aspire X1200-B1601A  PC Desktop Logo
712 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
