Question about Dell Latitude C400 Notebook
Dell Latitude C400 LCD Screen problem
I picked up a C400 that works fine through VGA but not LCD screen. At first, when I powered up the screen showed text but within 30 seconds it went to 6-8 vertical white blocks and never been able to show anything again. If screen would of went black, I would of suspected either inverter or bulb. But in my case it does light up but no text. Any ideas? The screen is not cracked.
  • 1 more comment
  • geminiys Mar 29, 2008
    Thank you for the link to the manual but I am not looking for replacement guideliness. I did take the panel apart and inspected the wiring but found everything to be intact. I am looking for help to point on what could be a problem with my screen.
    Thanks for pointing out the Fn/F8 button. I am aware of this feature to switch between LCD and VGA monitor. My issue with LCD screen itself. The screen light lights up but has no text to display, where VGA works fine. What I am trying to identify if this is LCD screen issue itself, or maybe cable is damaged, or Motherboard graphics chip is dead. My assumption, if VGA works, the MB Graphics chip is alive. I have carefully looked at the cable behind the screen it looks in good shape. Since LCD lights up, the Inverter Board and the bulb are functional. What could it be? Anyone had similar issue like that? Please point me in the right direction. Thanks,
  • Edroid May 07, 2009
    Hi, I´m Edroid, I have the same c400 screen problem, it was working good with windows 2000 but it gat a virus, so I decide to upgrade it to win xp and when it first started the screen went blank, then I conected a external lcd and it works good I did the bios upgrade to A12 then it was working good about 3 months, then i started to jump to the left about 3" for some minutes and fix alone , then one day it started to freze the screen and never come back again, so a lot of people recomed to change the panel so what can we do? to get a used one?...
    Guru:
  • 125 Answers
Of what you wrote it seems like it is a display controller fault :( you should replace the panel!
/Bruce
Posted on Apr 20, 2009
En cuanto la tienes mi correo es luis_felipe316@hotmail.com
Posted on Mar 29, 2008
  • 111 Answers
  • Clifford Hardy
    Clifford Hardy Mar 29, 2008
    there is function button hold it down then press crt/lcd or f8
Laptop will not bootup
I would plug in a cable to another monitor to see if you can get a picture. Most tv's now have a monitor link. You could also try getting on your computer through a network computer if you have one. If it works with another monitor you can use it to help you fix it. Dell has diagnostic programs on their site.
Feb 01, 2013 | Dell Latitude D630 PC Notebook
VGA DRIVER FOR DELL C400
Here are all drivers for Dell Latitude C400
Aug 10, 2009 | Dell Latitude C400 Notebook
How can I test if a battery for Dell Latitude C400 is working properly. I see the orange LED blink always when it is being charged, after it is unplugeed the system shuts off.
hello
You can check the battery by following the procedure written below.
  • charge the battery by connecting the charger.Look if it is showing the charging logo in the toolbar.
  • now remove the charger and go to screen saver option and select the power option.
  • there you will find power meter option.
  • it will show the battery logo.Now check the discharging rate of the battery.
  • this will tell you if tour battery is working fine.
thank you
Jul 19, 2009 | Dell Latitude C400 Notebook
Extrenal cd rom will not boot
Go into the setup menu on boot (before the windows screen appears) by pressing F2 or F10.
Go to the Boot Options and check that the CD-ROM/USB Device boots before the hard disk drive. Save and Exit.
Mar 05, 2009 | Dell Latitude C400 LCD DIsplay Bezel -...
Dell C400 screen image shaking
problem with the LCD cable...re instert the lcd cable
Jan 27, 2009 | Dell Latitude C400 Notebook
Dell C400 Resolution Problem
Boot into BIOS and go to the Video card setting, that sould fix it
Jan 26, 2008 | Dell Latitude C400 Notebook
Lat c400
you've probably set the screen resolution on your OS to high, connect an external screen, change it to some lower resolution, and retry
Dec 08, 2007 | Dell Latitude C400 Notebook
Screen wont show boot screen
fo to bios options by pressing f2 or del soon the power button is released. thre u can find an option to enable silent boot . turn it on
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
DELL Latitude C400
Go to the Dell website and download the XP video and display drivers:- http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=LAT_PNT_P3_C400&os=WW1&osl=EN
Feb 22, 2007 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
485 people viewed this question
Alun Cox
