Question about Frigidaire FRS6R4E Side by Side Refrigerator
Freezer is cooling fine, but fridge is not cooling properly
I have a FRS6R4EBA, the freezer is working great but the fridge doesn't cool, stays around 50 degrees. Manufactured in 2006. Any thoughts of what the problem could be?
    President:
  • 1,796 Answers
Hi!!
This could be due to few things, so let's start with the easy ones;
Check fridge temp. control.
Check fan in freezer (should come on if door is kept open a couple of minutes.) if fan does't come on,
or if weak (should come on strong), unplugg the unit and take back cover off, (should be 4 screws), test fan applying 110v AC to it, if defective, replace. If fan OK, check for iced up evaporator, if so, defrost using a heat gun or hair dryer, make sure air duct to fridge is clear of ice..
Adjust temp. settings according to manufacturer suggestion (wait 24 hrs. before adjustments)
Don"t forget to rate this post. Good Luck.
Posted on May 12, 2010
  • Frigidaire Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorFreezer is cooling fine, but fridge is not cooling - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
My gold star three door gr403s fridge isnt staying cold in the fridge section only. the freezer is fine but the middle chiller section is also having a few issues. Im not able to replace is as Im a pe
You might check this link for details that are similar to your fridge issue. Likely you do not have cold air fanning to the bottom compartment hence not cool. I assume your seals work properly and that it is a fridge internal issue.
Refrigerator Repair Not cooling properly freezing up on the back panel...
Feb 13, 2015 | Refrigerators
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
The fridge (kenmore) doesn't seem to be cooling but the freezer (on the bottom) seems to be working fine. Help! :((( Single mom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Refrigerators
Freezer works fine but fridge doesn't get to cold any more
heatman101
Jul 31, 2011 | GE Refrigerators
Freezer work great but the refridgirator doesn't get cold.
heatman101
Jul 06, 2011 | Refrigerators
I have a fridge that was made in 1995 that the fridge stays warm freezer works fine I also can not fine a model @ that I can read
heatman101
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Frigidaire FRS6R4E Side by Side Refrigerator Logo
231 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
