Frigidaire GLTF1670A Front Load Washer Logo
Anonymous Posted on May 12, 2010
I have a frigidire GLTF2940FS washer,that will not spin. It shows a code (E20)?
  • Anonymous May 14, 2010
    yes it was right on.
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on May 12, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3071369
Points
27242
E20 means a pump blockage and can be "easily" fixed at no cost. Here is how.
I tipped the machine back enough to safely lean against the wall, pulled off a few clamps on the coin trap hose. I couldnt get 2 of the clamps off as they were positioned away from me and didnt have the right tools to mess with it in that cramped space. from the main drum drainage i could feel the coin trap/filter and sure enough, it was absolutely disgusting. So in only a month, the lint from our new towels, dog hair, and gobs of dirt we managed to pack that filter, i got it out and cleaned it out, put it all back together and its good as new.
Here is what the trap looks like.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=408212&PPStack=1
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
E20 code keeps showing and you have to restart the machine so it will spin. Looking at a diagram of the motor and tub we are not real sure how easy it will be to remove the pump filter to clean. Can you...
Hi
You are right, E20 error code means that the drains hose/filter assembly is kinked and the water is unable to drain. If the hoses are clean/clear then please post back with the manufacturers name and model no of your washer for further assistance.
Daniel
6helpful
E20 message want spin
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
10helpful
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Front load Washer will not do a final spin
my front load washer wont final spin and show me e20 code
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
3helpful
2answers
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Error code E20. This is not listed on the error code chart. What do I do to fix the problem.
E20 means the drain hose is plugged or kinked or the household drains are plugged. YOur washer will not drain and spin until this is fixed.
turn off the washer/unplug it/remove the drain hose and check for a clog. If it is there, clean it out. If not - check your sinks and toilets for slow running drains. The garbage disposal is a good place to start as well. plug the sink, fill it with hot water, then pull the plug and start the disposal. That will help clean the disposal and also show you if you have a drainage problem there. Plunge the toilets, etc.
Good luck to you!
My washer wont spin out it has a code that is E20
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
