Question about Samsung SpinPoint SV1604E 160GB U133 5400RPM 2MB IDE 160 GB Hard Drive
Hard disk not being detected
I am using samsung HD 160 GB, past few days i my hard disk is not being detected by my computer, changed the cable data as well as power cable still no response , checked for any physical damage not found any,
it is still under waranty period please let me know what to do
thanks
  • 560 Answers
Take It back and get a new one .
Posted on May 12, 2010
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
Dane elec portable hard drive not recognised by win 7 pc
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use.
If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted.
If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off."
Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive.
Connect the cord directly into an outlet and power up the drive.
If the drive is powered and still not working, check the data cable.
Power down the hard drive and disconnect the data cable from the computer.
Wait 30 seconds to one minute.
Reconnect the data cable and power up the drive.
If the drive is not detected, power down the hard drive and connect the cable to a different port.
Power up the drive.
If the drive is detected but not working, check for a missing driver.
Click on the "Start" button, right-click "Computer" and select "Manage."
Enter your administrator password if requested.
Select "Device Manager" and double-click "Disk Drives."
Right-click the yellow exclamation point and install the missing driver. Close the Device Manager.
If the drive is detected but not working check to ensure it has an assigned drive letter.
Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer.
Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested.
Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add."
Assign a drive letter.
Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window.
If the drive is detected but not working, check whether the drive is in sleep mode.
Click the "Start" button, right-click "Computer" and select "Manage."
Select "Device Manager" and double-click "Universal Serial Bus Controllers."
Double-click the first instance of "USB Root Hub" or "Root Hub."
Check for the hard drive.
If the drive is not visible, move to the next instance of "USB Root Hub."
Continue checking each instance until the hard drive is located.
Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager.
Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Hope this helps
Nov 01, 2012 | Dane Elec DANE-ELEC SoMobile 500GB USB 2.0...
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
I am using Transcend 320 GB external hard disk in a Windows 7 Operating system. It is keep on asking me to format the disk while i plugging in to laptop. Unable to see the contents in the external hard...
guess you are using a USB port to for that.....
1 - check the cable that connects the HD to the USB port...change the cable and verify
2 - connect to another PC and check if it's ok there
3 - bring another ext HD from a friend and try conencting that....check if that's OK
4 - there could be a corruption in the HD that is preventing the PC from reading it
cardinal rule for USB....not a very dependent device specialy if connecting thru USB data cables....
solution
always use a good qty USB data cable compatible with USB2....as some cheap cables are only for USB1
visit my website
www.sureshayyar.110mb.com
for more info on PC issue and solutions...
reg
Kris
Feb 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Does not read on computer
Could you plz specify the brand of your HD?
which operating system do u have?
go to diskmanagement and assign any letter to your HD.
or u can change the hardisk kit and then see if it works.
Jun 08, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
I hav a 20 gb samsung hard disk, which the computer is now not detecting. i need to urgently recover sum data from it. how do i do tht??????????
the best method is to remove it and install it on a different PC...ensure that if it's a IDE drive(the white / grey data cable inside will be about 3 inch wide) then install it only in a similar machine....if it SATA(the red data cable inside will be 1 inch wide ) then use in that type of machine...recover all data....to that machine...use a 24gb USB pen drive to trf all data to you machine....
format the 20 gb HD and try to install it in the old PC
guess this solution will work...
reg...
pls leave afeedback...
May 10, 2010 | Quantum Fireball Lct15 (QML20000LC-A) 20...
External HD is not detected by laptop Windows XP
A common issue...I'm sure your hard drive is working fine, Windows is just not giving it an unused drive letter.
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
Feb 09, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
What to do if the disk is not detected?
Hi ctieprabanda,
Check your bios, to see if it detects it there? If not switch the sata cables and try. If that doesn't work , then you have a dead drive.
Good Luck,
Mark
Nov 09, 2009 | Western Digital Caviar SE WD1600JS...
My hard disk do not detects by the machine.
Thanks for using fixya.
If your computer doesn't detect the hard drive, its possible that:
1. There is a problem with the data cable for the hard drive. Change the SATA cable or IDE cable.
2. Power connection to the Hard drive might be loose. Make sure its connected properly.
3. The hard drive may be bad already. The best way to find out is to try and connect it to a different computer.
4. Its also possible that the port on the motherboard is already bad but this seldom happens.
Jul 16, 2009 | Samsung (SP0822N) 80 GB Hard Drive
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Samsung SpinPoint SV1604E 160GB U133 5400RPM 2MB IDE 160 GB Hard Drive Logo
241 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
