Question about Hyundai ImageQuest L70S 17" LCD Monitor
Power button flickers green and no display
What does it mean when the power button on my Hyundai L70S flickers green and no display on the monitor.
  • 11,361 Answers
It can be that it is not getting the signal from the PC, or it detects short circuits so it goes into shutdown and try to restart, or failed power supply due to bad caps. Try it on another PC and also check the VGA cable first. If it still does not work and you want to DIY repair, then please read below and look at alot of pictures so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 12, 2010
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Do I need a special audio wire to go from my monitor to the pc
Just mini stereo phone jacks male to male, Green audio line out on the PC to Monitor audio line in at the monitor. Try RADIOSHACK.
May 19, 2010 | Hyundai ImageQuest L70S 17" LCD Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Power on Green Light Blinks but no picture. Will not turn on. Hyundai Image Quest L705
bwpvemail, The units "switch-mode-power-supply" may be in shutdown mode. A tech will need to evaluate. Check to see if Hyundai has a refurbished swapout+cash program?? It's that or trade in for new wide screen, so the tech in the store "back-room" can possibly put $8 in new filter capacitors in your unit and with a little luck will have a 17" L70s for 1-2 more years use. 12fixlouie
Dec 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Jan 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
L70S Issue
Not sure if this helps but run my computer in safe mode and do a virus scan. This worked well for me, hope it helps.
Oct 12, 2008 | Hyundai ImageQuest L70S 17" LCD Monitor
Words are not clear
if its a crt monitor dump it,if its a lcd monitor try changing your screen resolution from display properties,or on the monitor check the brightness and contrast controls.
Dec 26, 2007 | Hyundai ImageQuest L70S 17" LCD Monitor
Hyundai ImageQuest L70S 17" LCD Monitor Logo
286 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
