Question about Delta 10" 3 Hp, 230V, Single Phase, Right Tilt Unisaw® 36 R31
How tight should the belts on my unisaw be? - Delta 10" 3 Hp, 230V, Single Phase, Right Tilt Unisaw® 36 R31
  • 623 Answers
I'd say so when you push on them in the middle you get about 3/4" deflection, snug but not guitar string tight either.
Posted on May 12, 2010
My Delta Unisaw quit spinning the blade even though the belts are fine. The blade is tight. The motor druns.
I would unplug saw and check if you can turn blade by hand the belts do not move. I would remove pulley and check key on abror shaft.
Sep 15, 2017 | Delta Saws
Unisaw single phase 3hp magnetic starter keeps blowing actuator coil
Should check the voltage on the coil if its a 220 volt saw could have a 120 volt coil
Nov 07, 2013 | Delta NHD STARTER SWITCH ASSY. FOR UNISAW...
Delta 10 inch unisaw switch hums wont start motor
All of the above are correct. However, before you go nuts with motor stuff, unplug the saw and make sure the blade shaft turns freely, If it doesn't, look for something jammed in the belt and pulley mechanisms. Loosen the drive belt and check the motor shaft rotation and the blade shaft rotation separately. If you find nothing, remove the belt and try starting the motor. If it won't start like this (no load) there is a motor problem. If it does start, find the drive mechanism problem and fix it; not many possibilities. Good luck.
Sep 23, 2012 | Delta X5 3Hp Left Titl Unisaw with...
Delta Unisaw 34-782 Starts with a "Bang"
The capacitor is probably failing. Take the motor to an electrical service center (most mid-to-large cities have them ... usually something like "Industrial Electric and Motor Service" ... and ask to have it checked. Caps are cheap!
Nov 02, 2017 | Delta X5 3Hp Left Titl Unisaw with...
Unisaw Jet Lock rip fence set-up
Go online to OWWM.com and download the manual. Don't forget to make a contribution. This will give you the step by step instructions for setting up fence. The jetlock is pretty easy.
May 23, 2009 | Delta 10" 3 Hp, 230V, Single Phase, Right...
Delta unisaw W/LVC
I think this is what you're looking for:
http://media.ptg-online.com/media/dm/OwnersManuals/20040331153155_En438-01-655-0002-04-01-04.pdf
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 29, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Delta 10" 3 Hp, 230V, Single Phase, Right Tilt Unisaw® 36 R31 Logo
157 people viewed this question
Top Delta Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Delta Measuring Tool and Sensor Expert? Answer questions, earn points and help others
