Question about Cameras
I HAVE A WEATHERPROOF COLOR DAY/NIGHT IR DOME CAMERA MODEL# DCD110043 THE CAMERA CABLE GOT CUT AND DAMAGED HOW CAN I REWIRE IT TO MAKE IT FUNCTIONAL AGAIN
  • lovelyliones May 12, 2010
    ITS ACTUALLY THE BNC CONNECTION CABLE(NOT A USB) WOULD I STILL FALLOW THE SAME PROCEDURE?
  • Cameras Master
  • 4,924 Answers
If the cable (data cable usb I presume) is damaged on a portion of i t...just cut and remove the part ..than weld the wires on by one by color...and isolate them one by one ...they are not that sensitive ..and it will work ...I myself even made a cable for a camera from 2 different damaged cables and it worked..Just have patience ..and see that it has 5 wires 4 colored and a ground for screening ...it will work ..they are colored and you can not miss anything ..I suggested tin weld for better result ...and the actual isolation can be any tape you have in handy ..just be patient and put then together ..
Posted on May 12, 2010
  • Catalin Turcu
    Catalin Turcu May 12, 2010
    basically is the same ..it will work until you get a new one ...it kinda much simple cause is either twix or triaxial ..and so have fewer cables inside ...if the damage is almost to the BNC end...and the plug is not one piece but can be removed without damage ...I will go for shorting the cable and just replace the plug at the end...if not just connect them by color and will work ...just be sure to isolate them well keep the weld as minimal as posible ...(short ends for minimal exposure to avoid interference ) and if the nul is like a screen ..(cover the others ..) try to put it the same way ..cause a low current flow in it ..is screening the magnetic outside interference ...but for a camera is not that sensible..is other for live signal...or audio ....cause there will be a background noise..
5 wire security camera wiring diagram
standard cctv camera wiring
red for + 12v
black for comm
yellow for + v (+video signal)
white for -v (-video)
Jul 09, 2014 | Lorex Corp SG6184S Weatherproof Mini Color...
Manual for a ASTAK CM 818t night vision
Your request sent directly to Astak could yield the manual.
Jun 30, 2014 | Lorex Weatherproof Color Day/Night Camera...
How cn i find wire diagram for model mc7662 cut off connection?
Mine has a yellow,green,black and red wires which one is the audio,visual,positive or ground
my email is davisdustin55@gmail.com
Jun 24, 2014 | Lorex Corp SG6184S Weatherproof Mini Color...
IR light doesn't work on security camera.
nitevision is in monochrome.. but if the irs dont work in that camera need to either get an ir light for that unit or replace that specific camera..the ir board is burnt out..or disconnected..I have several systems in use at different locations and I do installs for residential locations..I get some of my units off ebay..
Jan 20, 2014 | Zmodo Surveillance CM-S38901SV 540TVL High...
Why is my Lorex mini color weatherproof security camera only working in black and white d not showing color ?
Make sure it is not in a really shaded area. If the camera does not see enough light, it will stay in black and white mode. If that is not the issue, you might want to contact Lorex directly with the Camera model number.
Dec 25, 2012 | Lorex Corp SG6184S Weatherproof Mini Color...
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Need wiring diagram for Lorex SG6184S. Cut off connectors and hardwired camera, not it does not work.
Lorex Corp SG6184S Weatherproof Mini Color Security Camera with Night Vision,where can i download manual,wanting to set it up to my vcr and clueless how this is done,i have camera's yellow white cables in tv[video/audio but unsure how to connect or what to do so i can record from vcr,please specifies
Sep 03, 2010 | Lorex Corp SG6184S Weatherproof Mini Color...
Manual
Well you can please follow the below link for the manual -
http://lorexstore.lorextechnology.com/pdfs/SY14Q5184CUQ-A-english.pdf.R1.pdf
Please post the model number of your security monitor if the above manual is not for your system.
Thanks for using FixYa!!
Good Luck!!
Apr 01, 2010 | Lorex Weatherproof Color Day/Night Camera...
CAMERA GOES TO BLACK & WHITE A HOUR AFTER RESETTING POWER ON IT A
The SSC-CD73V and SSC-CD73VT cameras
offer a “Day/Night” function to provide
optimized sensitivity in both day and night
shooting scenarios. As the scene illumination
reduces and the acquired image darkens, the
infrared cut filter is automatically removed and
the camera switches to B/W mode, requiring
only a minimum illumination of 0.2 lx.
Incorporating an optimized lens for the
“Day/Night” function, the camera can produce a
clear and crisp image under normal illumination
or when used with near IR illuminators. In
addition, “Day/Night” modes can be
automatically switched, or manually initiated on
demand through an external control signal.
Apr 21, 2009 | Sony SSC-CD73V Color Mini Fixed Dome...
Black and white picture
connect to a different video source and see if you still get blk and wht only if you still does could be a prob with your I R camera
Dec 03, 2008 | Lorex Weatherproof Color Day/Night Camera...
Cameras Logo
87 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
