Question about Soehnle 61319 Certified Classic XL Analog Bath Scale
I weigh 25 pounds
Bought the 61319 bathroom scale at Bed Bath & Beyond. It had a crocked red needle. I returned it for one with a straight needle. The second scale shows my husband weighs about 75 pounds and I weigh 25 pounds. We looked at the written material, no instructions. I'm very disappointed. Thought for sure Germany would be better than China. Thought is was supposed to be calibrated.
Kathleen Los Angeles
4 Suggested Answers
mazzion
  • 5 Answers
SOURCE: i weigh 14 stone and 8ibs i want to convert it to
just tap in to weight watchers .
Posted on Sep 18, 2009
  • 32 Answers
SOURCE: my weighing scale is not working
try checking the battery and installing a new one
Posted on Jan 12, 2010
  • 500 Answers
SOURCE: when set on lb,pounds, scale
Hi dogwalk564,
Make sure of the following:
Be sure to place the luggage in the dead center of the scale, this will distribute weight evenly across the scale, also try to keep it on a level floor, any slight incline or decline to a side of the scale, will give you a bad reading.
How do you know the scale is incorrect, how do you reference it to the current reading?
Kind Regards
JEDMEEYER1
* If this solution helped, please accept it
Posted on Aug 08, 2011
I have a wolfgang puck pressure cooker that keeps shorting out and tripping the gfci within 1-4 minutes. What can I do?
You may have a faulty GFCI...test it and again with a known good appliance.
If the GFCI holds, then you have a ground fault in the pressure cooker. Either disassemble the cooker to the electrics and fix the short or return the cooker under warranty.
Chances are you can even get a replacement outside of warranty if you talk nice to the company.
Google it and get the company website.
If you bought it from bed bath and beyond just return it, hopefully with the receipt.
Feb 25, 2015 | Wolfgang Puck Crock Pots & Slow Cookers
ERr
Are you talking 31 "Stone"? If so, I believe that comes out to 434lbs. You are lucky if your scales can read that high. For testing purposes, remove your shoes or more if you think your right at the upper limit. Or let a slightly lighter friend try it. I assume your talking "Stone" as used in the UK. Are you from there? (I,m in the US, in Florida.) Also, there should be a switch on the bottom of the scale (upper left corner) allowing you to switch between lbs, st and kg. You can try that as well, although the limit should be basically identical. If you tell me more, I can help you more.
(By the way, I weigh 197 lbs right now, that's 14 stone.)
May 19, 2013 | Health & Beauty
I bought towel bars at a yard sale and the wall brackets are missing. Is there any place I can buy the mounting wall brackets?
Yes, Bed bath and Beyond, they have the parts as well as lowels and home depot. Let me know if this helped by posting 4 thumbs. Thanks mike
Jun 12, 2011 | Gatco & Channel& Satin Nickel Towel Bar
My scale shows that i weigh about 30 pounds lighter than i do.
If this is showing your weight, how do you know how much you actually weigh?
Also, you should be testing on a flat, SOLID surface (bathroom tile works well).
Feb 28, 2011 | Conair Weight Watchers WW-87 Body Fat...
I purchases the Nostalgia Electric Cotton Candy Maker Model # PCM-805 yesterday at Bed Bath & Beyond. The directions, scoop and 2 plastic cones were missing. Can these be sent to me? (The store...
I would call customer service at Bed Bath & Beyond and ask for replacement parts. You might have to bring in your receipt. They should have no problem replacing the missing items, and if Bed Bath & Beyond doesn't have the items, they could most likely call the company for you.
Dec 07, 2010 | Microwave Ovens
The weight jumps around. If I get off the scale and on again, the weight changes by 5 pounds. I am sure neither weight is correct.
You're only suppose to weigh yourself once a week. Make sure you're doing it after you've gone to the bathroom in the morning and with no clothes on. Other than that, I'd make sure the floor you set the scale on is level and that you are holding very still while weighing.
Feb 28, 2010 | Conair WW60 Weightwatchers Scale
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Body Fat Reading Changing Drastically
The fact of matter is those devices are inacurate for some reason more so on smaller females. But if you recently took a bath or drank water it will alter the results, they suggest taking it first thing before bath or eating in the morning at same time everyday to get a more acurate reading.
This may be getting personal but implants will also affect the reading making it totally useless for you to use. I have them and the electrical impedence devices read me much higher then what i am, a few minutes later will read me lower.
I would head down to your gym most of them will do a free body fat test with the calipers which is more acurate (as long as they know what they are doing).
Jan 01, 2009 | Homedics SC-405 Digital Bath Scale
Soehnle 61319 Certified Classic XL Analog Bath Scale Logo
18 people viewed this question
Top Soehnle Health & Beauty Experts
Tom Chichester
Michelle Balcom
Greg P
Greg P
Are you a Soehnle Health and Beauty Expert? Answer questions, earn points and help others
