Question about Insignia IS-LCDTV32 32 in. Television
Insignia big screen HD TV is cutting sides of picture off- words, etc. When we first got it did not have this problem. Adjusting different picture modes doesn't help.
Volume sound is printed on screen want to remove
Posted on Apr 08, 2011
The picture is too big for the screen. how can i make the picture match my screen size?
Posting the model number would make a response more valid but you need to go through the main menu selection and check to see if you can alter screen resolution or geometry there.Most sets offer different views such as 'Panorama,' 'Full screen,' etc.
Nov 21, 2011 | Sanyo Televison & Video
Words at the bottom of the screen
See if you have a button called ARC on your tv remote.. you will have different modes called Wide, Zoom, normal etc., Just put it in normal mode!
Mar 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
Insignia 32" 720p Flat-Panel LCD HDTV - High-Gloss Black Picture is too big for screen ,cut off all around, top, bottom and sides. Can't read things on screen, heads cut off etc. I've gone through...
try checking the menu setting on your Dish Network, there may be a television format in that menu set up, if it is only when a dvd player is playing, then check the format on that, so on so forth... that is one place to start, check if it is local (TV) or if it is from attached component ( Dish dvr/ dvd etc). also refer to your owner's manual.. if all else fails, call customer service @ insignia
Oct 17, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
There is about an inch on each side of my screen that is cut off and I can't see it. What do I do because I don't have the remote? I have the Insignia NS-27HDT 27". thank you.
you need to set pix format you might try using a universal remote or check menu on tv for pix format and size like full zoom etc.
Oct 10, 2010 | Insignia NS-27 TV TV
Picture doesn't fit on my Samsung HDTV
after searching around on both remotes for me...im with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
Sep 21, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
No Non-Hd sound
In a nutshell, there is no solution to this problem. The new Insignia TVs have a compatibilty issue with certain HDMI connections. The best thing is to return the TV and purchase another brand. I bought the LG w/built-in DVD and everything works great.
Feb 05, 2009 | Insignia LCDTV26 26 in. Television
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No Non-Hd sound
a2d70c9.jpgdid you remember to put audio leads in
Nov 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
228 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
