Question about Alpine MRD-M1001 Car Audio Amplifier
WHERE CAN I GET A BASS KNOB FOR ALPINE MRD-M1001
  • 1,596 Answers
Any AUTHORIZED DEALER of this Product Although this Spacific Part May NOT be Available, Not EVEN From Manufacturer.
Posted on May 12, 2010
Got light but buffer are not working
the connections are not correct or fuse is damaged
Apr 26, 2011 | Alpine MRD-M1001 Car Audio Amplifier
It has no output and isnt reading that there are any ampres on the meter
hi
i looked at the manul and came a cross this if it helps
No sound is produced.
• The output disable mode is turned on.
• Refer to the instructions at "Output Disable Mode"
to turn the output disable mode off.
Jul 17, 2010 | Alpine MRD-M1001 Car Audio Amplifier
Can i use a MRD-M500 for voice on my tweeters
not a good idea-its made to run bass- plus its a mono amp- so you would lose stereo separation-but if your mind is set on it....do what you gotta do and good luck
Jan 09, 2010 | Alpine MRD-M500 Car Audio Amplifier
Amp keeps blowing fuses (alpine mrdm1001
Hello prabh_dusanj,
First make sure that the amp is not operating into too low of an impedance. If the load is OK, it's most likely a short in the output transistors.
Hope this helps.
Sep 11, 2009 | Alpine MRD-M1001 Car Audio Amplifier
I have an alpine mrd-m1001 getting curr message ho do you reset the amp
Hello deeprajm,
Shorted or low impedance outputs can cause the "CUR" display. Power down everything and remove the speaker wires. If it will then power up without the display, the problem is probably a short in the speaker wire or voice coil, or the impedance load is too low. If there are multiple subs, reconnect them one at a time to isolate the bad one and then correct the problem. If the amp works properly with either of the subs but not both, rewire the subs for a higher final impedance.
If the amp still displays "CUR" with the speakers disconnected, there's most likely an internal fault that requires component level repair.
Hope this helps.
Aug 01, 2009 | Alpine MRD-M1001 Car Audio Amplifier
Watts
The MRD-M300 has speaker-level inputs so you can easily use it with any car stereo. Hook it up and hear what good bass can sound like!
Details:
  • 150 watts RMS x 1 at 4 ohms
  • 300 watts RMS x 1 at 2 ohms
  • MOSFET power supply and output stage
  • STAR Topology for cleaner sound
  • Bass Engine® features:
    • low-pass digital crossover, 30-200 Hz, 24 dB/octave
    • variable subsonic filter (15-50 Hz in 5 Hz steps)
    • parametric EQ variable from 30-160 Hz
    • Bass Compensator enhances low-end definition
  • top-mounted digital control center with cover
  • time correction 0-10 milliseconds in 0.5ms steps
  • phase correction 0-180° selectable
  • digital readout
  • detachable front cover
  • blue power LED
  • delayed turn-on
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • speaker- and preamp-level inputs
  • gold-plated terminals
  • 8-5/16"W x 2-11/16"H x 11-1/2"D (10"D without front cover)
  • 1-year warranty
May 29, 2009 | Alpine MRD-M300 Car Audio Amplifier
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Alpine mono power mrd m500 amp
Try switching the lowpass filter down to 80hz or lower, then adjust the bass boost to your liking.
Jun 28, 2008 | Car Audio & Video
Alpine MRD M301 just flashes
disconnect all inputs and outputs then restart it if problem persists you have a internal solder bridge youll need to have it repaired by authorized repair shop or buy a new amp at wholesale from this site:
www.godspeedaudioheaven.com
Mar 11, 2008 | Alpine MRD-M301 Car Audio Amplifier
Alpine MRD-M1001 Car Audio Amplifier Logo
133 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
