Question about Canon PowerShot G9 Digital Camera
Lens error,restart camera
El lente esta afuera,no entra y tiene un sonido cuando se prende
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
t00nz
  • 4738 Answers
SOURCE: Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 28, 2009
ginko
  • 19396 Answers
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
  • 64 Answers
SOURCE: Lens error: restart camera
If you get that message the lens is stuck.
You should take the camera to a repair center.
They should repair it under warranty.
I have seen this problem a few times already.
Posted on Sep 12, 2009
  • 11967 Answers
SOURCE: My Canon A590 is saying lens error restart camera.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 29, 2009
  • 1382 Answers
SOURCE: lens error, restart camera lens got pushed in
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Thank you!
Posted on May 18, 2010
Prende el motor
tengo problemas con un bmw 2008 528i se prende en el tablero la figura de la maquina y una como herradurita y no prende que es puede ser la bateria aunque tiene luces
Jan 08, 2014 | Kia Cars & Trucks
Hola no hablo bien ingles solo quiero preguntar mi montana se calento, revize el deposito del antifrez y esta lleno las mangeras estan muy duras como con mucha precion que podria ser
probablemente wl problema que tienes es un mal termostato. Cambialo porque parece haberse quedado pegado en la pocision de cerrado haciendo que se caliente tu carro y que las mangueras se pongan duras debido a la alta presion de coolant super caliente. Un cambio de termostato arreglara tu problema.
No olvides dejar tu commentario y votar por mi ..esto me ayudara y puedo segui ayudando a gente como tu y especialmente de habla hispana. Gracias
Mar 07, 2011 | 2001 Pontiac Montana
En la pantalla de mi camara digital kodak c140 sale un error de lente error 102 por favor decearia que me expliquen por que salio este error y como solucionarlo les agradecere mis correo es...
Error de lente sinifica que hay un problema en la extension or retraccion de la lente. La placa base detecta que la lente no se puede mover y hay tienes el eror de lente.
Lo unico que se puede hacer es intentar ayudar suavemente el movimiento de la lente mientras que se encende o apaga la camera. Si esto no sirve, llama Kodak al numero que se encuentra en el manual de uso.
Aqui ay un artculo que trata el problema (en Ingles). Los codego son los de una camera Sanyo, la situacion es la misma que se encuentra en Kodac con error 102.
Hi. If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 pro
Sep 04, 2010 | Cameras
Tengo el problema q de mi portatil extensa 5230 series el encendido de la pantalla y el encendido del teclado me han quedado inutilizados, y no me deja utilizarlos en modo normal pido por favor un concejo...
Primero, se prende su computadora normalmente? Que hace su teclado cuando la computadora esta prendida? Hay algun error que aparece un su pantalla? Desde cuando tiene este problema? Installo algun programa antes de que pase este problema??
May 17, 2010 | Acer Computers & Internet
Tengo problemas con el aire acondicionado esta tirando aire muy caliente aunque este en aire acondicionado.
Ok tienes que revisar si el compresor trabaja cuando activas el interruptor del aire si el compresor no se activa podria ser que le falte freon 134a al sitema,que tengas algun problema electrico.puedes comprobar el nivel de freon con un manometro si este esta bien tienes que revisar la parte electrica. Gracias
May 03, 2010 | 2002 Kia Sedona
Mi camara v1253 kodak prende y rapido se apaga.
La camara de KODAK tiene ese problema mucho no compres Kodak compra Nikon i tira la Kodak porque ese problema no se pude arreglar cuest mas el arreglo que la camara.
Sep 21, 2009 | Kodak EASYSHARE V1253 Digital Camera
Sonido en la rueda derecha
Si el sonido se verifica como apreta los frenos, y es como un rascar de metal, entonces tiene que sostituir las pastillas de freno.
Si el sonido esta todo el tiempo, quando se tuerce el volante, y es como un rascar o como un sibilo, tiene que veer con la parte que en ingles se llaman wheel bearings.
Oct 02, 2008 | Mazda 626 Cars & Trucks
Como cambiar la lampara
si ves la tv por el frente tienes que quitar el grill the las vocinas, es muy facil, agarra el grill y hala hacia afuera, solo tiene unos clips,luego mira hacia la parte central de la tv y veras unas letras negras y tiene la informacion de la lampara.hay 3 tornillos que tienes que quitar(desarmador philips) luego veras la lampara nesecitas un desarmador plano y son otros 3 tornillos.aflojalos y hala la lampara hacia afuera.luego installa la lampara nueva haciendo el proceso alreves. hacegurate de poner el covertor de la lampara antes de encender el televisor. y si te pregunta si cambiaste la lampara preciona enter(cuando enciende la tv en letras en la pantalla.. buena suerte .
hdtvman.
Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Canon PowerShot G9 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
