Question about Sony STR-DH700 A/V Receiver
Sony STR-DH700 receiver
I am on my third amp and now probably going to #4. When listening to it (fairly loud) all of a sudden it shuts off and then that's it - push power and it only clicks. This has happened to all three of them now. The one prior went into protect mode and would turn back on - we determined that it was an issue with the speakers and replaced them - that does not happen anymore. I unplug it - nothing. Are there any known issues with this amp? It's not that bad of an amp. It is connected to a bunch of Klipsh surround speakers with a 450 watt sub, a sony blu-ray - shaw cable box, another regular dvd player....
Thanks
..Greg
    Brigadier General:
  • 8,546 Answers
The one common component in this case is YOU. Maybe you might look at the impedances of your speakers to make sure you're not presenting too little to the amp. And turn it down. It's not like the result is totally UNexpected.
Posted on May 12, 2010
Output transistor
the sound section on the unit had a short circuit,take it to repair,thats why it protects it self.
Oct 04, 2013 | Sony STR-DH700 A/V Receiver
Multi channel av receiver str dh700
un plug ac power. then disconnect all the speakers. plug in ac power and turn on. Still in protect? Could be blown amplifier.
Not in protect? one or more of the speakers or speaker wire is shorted
Aug 25, 2013 | Sony Audio Players & Recorders
Sony av receiver #str-dh700. only could hear relay clicking when i press power . the system could not be come on . what it be / & how to repair it?
One of two things. Either the main power fuse is open or the power transformer is bad. If the fuse is blown, then it usually means you have a bad amp channel that needs to be repaired. If it's not the main fuse, then the thermal fuse in the transformer may have opened which requires the transformer to be replaced.
Jul 03, 2013 | Audio Players & Recorders
No sound when hooking receiver to subwoofer using standard red RCA cable. Do I need a subwoofer cable?? I have turned my tuner subwoofer to YES, powered up receiver and subwoofer but nothing.
Probably not if it takes RCA input, but the receiver needs to be informed of the sub's presence and hw you want to share low frequencies among the rest of the speakers and itself. Then you need to set the relative levels using test tones, which also proves the sub works.
http://www.retrevo.com/support/Sony-STR-DH700-Receivers-manual/id/23341dj691/t/2/
Page 102
Set the subwoofer to YES (Page 43)
Jan 17, 2011 | Sony STR-DH700 A/V Receiver
What could I use to connect my speakers to the back panel of the STR DH700. My home was prewired with speaker wires for surround sound. I used banana plugs for the other speaker wires but finding hard to...
Had a set of bose AM-10 that I had to take back cuz Sony said that their receivers needed a powered sub woofer. got AM-15's and hooked them up-AMAZING SOUND.
Dec 08, 2009 | Sony STR-DH700 A/V Receiver
I HAVE A SONY RECIEVER STR-DH700, I get no sound
make sure the FM antenna is connected and in a good place then check to see if the A-B speaker selector is selected properly.check to see that the sound field is set properly, My 800 allows for several different options and if your speaker wires are reversed or not in the correct position front left at front left etc it will not send the signal to those speakers. try using the TEST TONE feature if you have one it will send a signal to each speaker in sequence (LF< C< RF<in order) it will go all the way around to see if they are connected properly, that way you can tell if they are connected at all or in the wrong spot on the back interface. I dont know if that is what you meant by AUTO CAL, but that is a seperate feature when you use the connected mic to determine range, height and distance to the position in the room you are most likely to be seated for optimal sound.
Nov 29, 2009 | Sony STR-DH700 A/V Receiver
STR-DH700 won't power up unless I unplug-plug it.
This is a logic problem with the internal microprocessor. A quick experiment: Turn the unit on for about 2 minutes and shut it down. Doe sit power uip in this case? If so, I'd suspect that the heat generated during normal operation is creating an internal problem thaty is preventing the micro from recognizing the "off" condition. The power data line is hung and is not being recognizwed by the micro so any attempt to turn the unit on will fail. The unplug/re-plug essentially clears or resets the unit.
If the unit is new, return it for warranty repair. It will be important to describe when the unit fails however. Try to see how long it must remain on for the problem to occur.
Update this with your results if the unit is not under warranty and we'll try to narrow it down.
Thanks,
Dan
Nov 05, 2009 | Sony STR-DH700 A/V Receiver
Sound from reciever
LFE (ONE CABLE ON THE SUB TO SUB OUT ON AVR) OR stereo L/R analog cable from sub to tape in/or out on avr (depends on AVR) LFE connection the sub turns up with the AVR - the stereo cable threw tape in/out on AVR only turns up via its own onboard amp volume from AVR has no affect.
Aug 21, 2009 | Sony STR-DH700 A/V Receiver
Sony STR-DH700 A/V Receiver Logo
301 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
