Question about RCA HD52W59 HDTV Projection Television
Cable connector broken
I have a 52 inch RCA HDTV and the Cable connector has broken in the back of the tv.
  • eraquan Dec 16, 2008
    well the cable connector port has broken off how
    can i solve this problem
  • Anonymous Mar 29, 2014
    middle lamp is out
Where do i purchase the connector and how can I replace it?
Posted on Nov 07, 2008
  • Ronnie Lewis Nov 07, 2008
    What is solder? My tv has two connecter could the second connect that is sstill in place be used?, and if so, what and how I change th tv to program the second connector?
    What is a solder? My tv has two connecter, could the second connecter that is still in place be used? If so what and how could I program my tv to connect to the second connector that reads analog/antanna?
I stuck a sewing needle into my cable line (to give it length) and then stuck the needle inside the broken connector. I then duck taped it to make it stay connected to the back of the tv. This is a rednecks repair no doubt but it was cheap and easy!
Posted on Jun 19, 2008
    Problem Solver:
  • 7 Answers
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Posted on Apr 02, 2008
I have a rca d52w23 no caoax hookup what part do ineed to make my tv cable ready
The model you listed does have a built in tuner so there should be a connector on the back where cable TV would connect to. A very common issue on these sets is the connector often breaks off rendering the tuner useless and therfore requiring replacement of the tuner itself. You can use a cable box and connect it to either the component or composite inputs on the back of the TV. I hope that helps : )
Jul 25, 2011 | RCA D52W23 52" HDTV CRT TV
The antenna/cable in threaded piece has come out of the back of the tv. How can I fix that. I tried to put it back but it won't stay. I think I need a new one.
These sets have what is known as a on board Tuner. This means that the Tuner is not replaceable without replacing the entire Board. The good news is that you can replace the Cable/RF connector as long as the shield it attached to is not broke or too bent. Most of the Cable/RF connectors used in these sets have PCB mount . You will have to remove the Signal Board and unsolder the center connection of the broken connector left on the Board. Remount the new
Connector and solder the center connection. You may need a collar nut to secure the Connector the the shield.
I hope this helps,
Skyassoc
Nov 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have Samsung A550 46 LCD HDTV, and Anteina IN Broken
Yes it can be fixed if the tuner board was not damaged. Get an RF modulator, you can pick them up at walmart, and use your RCA inputs in the back. All you do is input your main tv cable into the RF mod cable in, then connect to the out of it with your RCA cables and then into the RCA connect in, into the back of your tv. Or, like you said, you can input your main tv cable into your vcr/dvd then come out of that with the RCA cables, and again into the RCA cable in on your tv. This way you have to syncronize your channels after you do this to get the picture. You know, vcr on channel 3 while your tv is set to input 1 or whatever needs to be done.
Jul 07, 2009 | Samsung LN46A550 LCD TV
Loose UHF connector
That connector is just press-fit into a metal shield around the set's tuner. It's commonly broken loose by overtightening the cable connection or tripping over the cable and yanking on it. In bad cases it can be broken completely off the set. It really doesn't "leak" anything but can cause a poor picture and allow interference to get in.
The connector can be soldered back into place with the aid of a suitable-size soldering gun. You should be able to find a TV servicer who still makes house calls. With labor and trip charge, I'd guesstimate around $100. The shop I worked for got $72 for this repair, and that was nearly 10 years ago. It is also possible for do-it-yourselfers to make this repair if they have the soldering skills. But even if you pay someone it's still less than the cost of a new set.
Jun 01, 2009 | RCA R52WM24 52" HDTV Projection Television
Hd hook up for rca 52"dlp
If you have Direct TV HD the best way is to use a HDMI to DVI cable. If you only have the component (red/green/blue)connectors on the Direct TV Box that would be the best way. You will not have audio using the DVI cable, so you will have to run Red/White cable to the Audio Input.
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Patgirl
The part is called and "F" connector. It can be purchased but it also muist be soldered in place. This is not a trivial task. The F connector is part of the tuner. For a set of this size, it may be easier to replace the tuner rather than fool around with a repair attempt. Depending upon how it was broken, the PC board inside the tuner may be broken as well requiring tuner replacement anyway.
Dan
Nov 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
Power falure
Check second ribbon on deflection board if not pluged in right set will make a small squealing sound and will not come on insert correctly set should then come on/.check and make sure all ribbon connectors are in good.
Oct 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken Cabel Connector RCA 52 HDTV
depend on how badly damage it might be.. as a tech i replace these all the time.. if you can solder it might be possible.
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken cable connection inside board
No need to buy a PC board. Have professional tech solder leads back and tighten connector
Apr 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HDTV picture problems
Does the picture just get dark or does the picture go out completely? Does it do this with both the cable and the DVD? Is the audio affected?
Jan 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
270 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
