Question about Polaris Pb4 - 60 Booster Pump
I turned on my pump today and it made a huming buzzing noise. What could cause this ,and how do i fix it?
  • 12,061 Answers
Your Motor is either "Bound Up" stuck, jammed, whatever, or the motor has burnt out, or the controller is. You need to use the manual, & sites below to try and troubleshoot your problem. www.electricmotorwarehouse.com/PDF/polaris_manual.pdf wetheadmedia.com › All CategoriesDIY Pool Repair
www.epoolshop.com/polaris_booster_pump_pb-4_parts.aspx
These above links are the manual and troubleshooting links.
Posted on May 12, 2010
Huming noise when I turn my steering wheel
sounds like you are low on power stearing fluid check level
May 07, 2015 | Ford E-Series Van Cars & Trucks
Polaroid flm-373b lcd tv - making a loud buzzing noise. Picture is fine.
Possible that the main power supply unit which is the SMPS- switch mode power supply- has a faulty capacitor or in the INVERTOR board which has changed the value and so the frequency being changed can cause higher huming level- reduced to lower frequency.
so check the board for leaks , if so replace. Also check if the threshold voltages are below level in these circuits. if so the capacitor can be identified. If there is change after the component heats then simulate the circuit board and confirm using a hair dryer.
Sep 23, 2011 | Polaroid FLM-3732 Television
Hotub clicks and then makes buzzing noise when turned on.
does it blow a breaker? check to see what is going on by unplugging all the pumps, blowers lights and anything else plugged into the circuit board (heater too)
turn the breaker on once everything is unplugged and then proceed to turn the spa off, plug one item back in and turn the breaker back on.
Do this until you find the buzzing....
You may actually have a back relay on the circuit board causing the buzzing by not latching in when the pump or something is trying to come on.
Rod
Aug 23, 2011 | Home
Vibrating noise in the drivers side wheel when im going 55 on the highway and when i slow down
Hi If the noise is like a buzzing or huming noise the most likely cause is the wheel bearing.
But if you are feeling vibration through the steering wheel at 55 then as you increase speed the vibration goes then thats usually the wheels need balancing.
Also some noises can come from brakes which are rubbing or lots of brake dust on them.
Anyway i hope i have been of some help to you good luck
John ( South Wales UK )
May 07, 2011 | 2000 Mazda 626
Car started making noise and the wheel became hard to turn
Is the belt on the power steering pump tight or loose does the pump makes a huming noise when turning steering all these are causes of hard to turn steering belt need to be (tight) on pump and pump must not be huming when turning steering add fluid if needed and play with steering to see if help if not need to replace pump
Nov 12, 2008 | 2003 BMW 325
Buzzing until warmed up
This is caused by a defective capacitor in the power supply board. A very detailed answer is given by stiv0. His solution is for a "no power" or "black screen" condition, but this also fixed my noise on power up. I had noise that went away, but eventually it stayed on all the time. His explanation is correct except in describing how to get the back cover off. He says to take the 3 screws off the back of the black plastic cover on the back and then "pry" up the plastic. Actually if you slide the plastic down about 3/8 inch the cover will lift out easily. I fixed mine today in about an hour.
Hope this helps.
Trent
Sep 10, 2008 | Polaroid FLM-3732 Television
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Spngbob TV Makes buzzing noise when plugged in and wont turn on
Bad horizontal driver or output transistor/trnsformer. Look for serious service for this set...accordianman
Oct 19, 2007 | Emerson SpongeBob SquarePants TV
Polaris Pb4 - 60 Booster Pump Logo
779 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
