Question about Microsoft Windows XP Home Edition
USB2 Problem Windows thinks My card is USB1.1
Hello
I have a problem with a GMU2P-04V USB2 card. I have a K7VAT, VIA KT-133 CHIPSET and ATX Form Factor Main Board. I have the latest BIOS and run XP Pro sp2 which has all the latest updates. There are 4 ports on the card and 2 USB1 ports on the back of the original case. I have tried searching for new driver updates and have installed the 2.1 March 2008 edition which was the latest I could find.
The problem I have Is no matter what Port I use for connecting a USB2 device Windows throws up a pop up saying this device will run faster if you connect it to the USB2 port, and shows 4 empty ports, when in fact they are all occupied. I have the original installation cd with the drivers but XP installs its own drivers before you have a chance to, also the instructions say it the card supports XP but the driver folder on the CD only mentions ME and 2000 editions!
Also in device manager it shows I have an advanced host USB and relevant usb roots installed OK.
I would be most grateful if you could throw some light on this subject as I have been trying to resolve the issue for a number of years now.
Does any one know if my motherboard does support USB2, if not can you buy any external device that will work?
Kind regards Mr B. Hutchinson
  • semaj21 Mar 29, 2008
    Hello Krenn
    The four USB2 ports on the card are occupied by USB2 devices but windows reports that they are plugged into a low speed device!! In device manager the Highspeed device and drivers are reported as Ok!! The two USB1 ports are built into the motherboard. I have a feeling the motherboard does not support USB2. I have the latest Bios upgrade from AWard but the bios does not mention USB2. The manual for the motherboard says that there are four USB ports, but there are only two external one marked USB 1 and USB 2 I dont think it means (USB2) inside there is an 8 way connector block which is marked as USB2, I have no idea what that is. I have the CD for the card but XP loads its own drivers saying they are better than those on the disc.
    Any help appeciated. Also if the mother board does not support USB2 is it correct that The USB2 card I purchased will not work, I might have a case for a refund as I purchased it from Novatech who sold me the computer and the card.
    Regards Barry
    Hello Krenn
    Thanks for that, I have had this problem for some years now and have not been able to resolve it, I have tried all different forums even the VIA manufacturers themselves and judging by google searches I have done there are hundreds of people out there with the same problem. I have a Cannon scanner which is USB2 when plugged into the card windows says I have plugged it into a low speed hub, I also have a USB2 external hard drive plugged into the card and get the same results also NTL cable modem.
    Where can I purchase these connectors you mention??
    Once again thanks for taking time out for me.
    Barry
  • 59 Answers
What do you mean when you say that the 4 USB2 ports are all occupied?
when you say that there are 2 USB1 ports on the back of the case: are those ports connected to the motherboard at all?
what devices are you using to test your USB ports? is it possible that those are USB 1 devices?
Posted on Mar 29, 2008
  • Anonymous Mar 29, 2008
    ok... if there are 8 pin connectors on the motherboard marked USB2, you would use those by purchasing a little plate with USB2 connectors, and screwing that onto the case. then you would plug wires on the back of those USB2 connectors into the 8 pin connectors on the motherboard.
    If you have a seperate PCI card plugged into the motherboard, with USB2 ports mounted directly on the card, that should work, even if the motherboard itself does not support USB2.
    however, you may have to install drivers specific to the PCI card.
    Once again, what sort of USB devices are you using? if the USB device, like a zip drive or flash memory stick, is only USB1 compatible, then it won't matter what kind of USB port you plug it into.
SOURCE:
Drivers 7vba-2aa5
Hello the drivers from this site should fit your mainboard:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Please unzip the files bofore you install.
Install the 4 in 1 chipset driver first and reboot.
Install next the sound driver.
Here is also the VIA site:
http://www.via.com.tw/en/support/drivers.jsp
Here is some info:
SY-7VBA 133
Description
- 66/100/133 MHz FSB FC-PGA 370 Based ATX Motherboard
Processor
- FC-PGA 370 Pentium III Processors with 100/133MHz FSB
- Socket 370 for Celeron Processors with 66/100MHz FSB
Chipset
- VIA 693A + 686A Chipset
- 66/100/133MHz CPU FSB
System Memory
- Three 168-pin SDRAM DIMM sockets support up to 1.5GB
- PC133/PC100 DIMM support
- Provides ECC (Error Checking Correction) capability
On Board Audio Subsystem
- AC97 CODEC on board to provide audio solution.
SOYO has closed there support site many years ago.
Good luck
Jan 11, 2013 | Soyo SY-7VBA133 Motherboard
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
Manyal
EP-8K3A
Introduction
KT333 with VT8233A AGPset/266MHz FSB/3 DIMM with DDR333/1 AGP-4X/6 PCI/USB1.1/ATA-133/6CH Audio/ATX
Specification
PROCESSOR:
The Socket A compatible AMD AthlonTM XP processor 1500+ to 2700+, 600MHz to 1.4GHz AMD AthlonTM and AMD DuronTM processor up to 1.3GHz
CHIPSET:
VIA KT333 AGPset (KT333+ VT8233A)
DRAM MODULE:
184pin DDR DIMM x 3 for PC2700 Memory
DRAM Size: 64MB to 3GB
EXPANSION SLOT:
PCI x 6!A4X AGP x 1
ONBOARD I/O:
Winbond W83697HF LPC I/O integrated with FDD, Parallel, Game, Serial and IrDA v1.0 and Power-On Controllers
ONBOARD PCI / IDE:
PCI Bus IDE Port with PIO / Ultra DMA-133 x 2 (Up to 4 Devices)
I/O CONNECTOR:
PS/2 Mouse and PS/2 style Keyboard
COM1, COM2, Printer, Audio-in/out, MIC & Game Port connectors
USB:
USB connector x 4 (2 for Opt.)
BIOS:
Award Plug & Play BIOS
Built-in AC97 Digital Audio (by Realtek ALC650):
Compliant with AC97 2.2 specification
6 channel slot selectable DAC output for multi-channel applications
Supports digital SPDIF Out Function
EXTENDED FUNCTION:
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports CPU Vcore , Clock and Multiplier setting via BIOS
Supports Memory Voltage setting via BIOS
Supports STR (Suspend To RAM) power saving Function
Supports Wake-On-LAN Function
FORM FACTOR:
305mm x 245mm x 34mm ATX Size
OS Supported:
Windows 98SE/ME/2K/XP/Server2003
Jun 05, 2011 | EPoX EP-8K3A+ Motherboard
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I need specs
Here is the specs of the mobo.
Product MPN MPN sv266m Key Features Form Factor dtrquestion.gif Micro ATX Compatibility PC Chipset dtrquestion.gif VIA ProSavageDDR KM266 Compatible Processors AMD Athlon Processor Max supported CPUs qty 1 Memory Memory Type dtrquestion.gif DDR SDRAM Max Supported RAM dtrquestion.gif 2 GB Audio / Video Audio Output dtrquestion.gif Sound Card Video Interface dtrquestion.gif AGP 4x Communication Networking Type Network adapter Other Features Chassis Type dtrquestion.gif Desktop Package Qty 1 Dimensions Depth 9.52 in. Width 8.97 in.
Dec 03, 2009 | Syntax SV266M Motherboard
Update for chipset via kt 400a
hiiii Please goto this site i.e. http://www.viaarena.com/default.aspx?PageID=2 and as per your selection of OS you can find you driver of your motherboard.
Feb 18, 2009 | VIA P4MA Motherboard
My computer restarts before installation completes
GO INTO SAFE MODE REMOVE ALL OLD DRIVERS AND ANYSOFTWARE THAT MAYU CONFLICKS AND RESTART SYSTEM
SAFE MODE MAY ALLOW INSTALLATION OF NEW DRIVERS IF SO DO IT IT WILL HELP YOU ALOT.
IF NOR GOINTO CONTROLL PANEL SELECT NEW SOFTWARE LOAD NEW DRIVERS
CANDYMANGANDY
Jan 27, 2009 | Abit AX8 NVIDIA VIA K8T890 + 8237 Chipset...
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
Microsoft Windows XP Home Edition Logo
234 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
