Question about Philips PSS110/17 MP3 Player
Philips gogear 2gb/model SA3025/37 update drivers ? will power on but goes to screan that says connect to PC and use device manager to repair - how do i fix this ?????
  • 10,421 Answers
Hi team,i am facing problem with philips go gear 2GB player, Problem is :when ever i switch it on,"please connect to Pc and use device manager to repair" please help me in this scenario,explain...
I'm not a team member, but
1. Select your GoGear 2GB player from this list:
http://www.search.philips.com/search/search?q=GoGear+2GB&s=all&l=global&h=all&o=
2. When not having the program Philips Device Manager installed on your computer yet: Look under Software and Drivers, select the Device/Firmware Manager for your player.
2.1 Run the execute file Device Manager for installing the Device Manager toolbox.
3. Run Philips Device Manager:
  1. Having launched Philips Device Manager at Start -> Programs -> Philips Digital Audio Player -> SA2XXX -> Philips SA2XXX Device Manager on your PC
  2. Connect your player to the PC
  3. Device Manager should acknowledges your player and automatically goes into recovery mode.
  4. Follow the instruction of the Device Manager.
  5. After the player has been repaired, remove it from your PC and re-start.
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Feb 21, 2010 | Philips Audio Players & Recorders
It wont work
goto philips.com then under support and elctronics find your model and download the repair utility and run it on your mp3 player try that first you can also put it into recovery mode by holding the volume up button while you connect it to the pc
Sep 27, 2009 | Philips GoGear SA3125/37 MP3 Player
I turn on the gogear sa6045, the loading screan appears and shuts off at 35%.
Reset the player using the pinhole. If it freezes again, you need to update the firmware to resolve the issue permanently.
To update the firmware correctly:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Update" tab
-Tha Mp3 Doctor
Apr 02, 2009 | Philips GOGEAR SA6045 MP3 Player
My philips gogear 2gb keeps cutting on and off
Recovery Mode for Philips' GoGear
Open the Philips Device Manager and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 11, 2008 | Philips GOGEAR SA6045 MP3 Player
My philips gogear 4gb
Code 10 errors can be resolved by completely uninstalling the Philips Device Manager and other software that came with the GoGear installation CD, and then reinstalling the clean version of the software from the Philips website.  Then running a Repair. The version of the Device Manager that is on the installation CD is not the same version as the one from the website.
-Tha Mp3 Doctor
Philips GoGear 2GB memory corruption
You have to do the "update" in the Philips Device Manager (make sure you are connected to the internet when you do) to repair the corruption: Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Sep 10, 2008 | Philips GoGear HDD6330 MP3 Player
I pod
-Tha Mp3 Doctor
Aug 28, 2008 | Philips GoGear HDD6330 MP3 Player
My problem
lucky - make sure you are not using MAC or Windows Vista. Make sure the software is installed. Try another usb port in your computer. Try a usb port on another computer with same OS.
Suji - Recovery Mode for Philips' GoGear
-Tha Mp3 Doctor
Aug 23, 2008 | Philips GoGear HDD6330 MP3 Player
My MP3 Player not turnning off
Make sure the lock switch is off. Reset method is power on plus volume + at the same time for 5 to7 seconds.
-Tha Mp3 Doctor
Aug 21, 2008 | Philips GoGear HDD6330 MP3 Player
Device driver problem
Grab the software directly from the Philips website at www.usasupport.philips.com - enter in your model #, click on software and drivers, then click on Device/Frimware Manager - this is a more recent version than that found on the installation CD.
Also, you can follow the FAQ process on the website which says "Player not recongized by PC"
If that fails, do a repair and a firmware upgrade:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the firmware upgrade by clicking on the update tab in Philips Device Manager. The firmware upgrade should resolve the issue permanently.
Jan 18, 2008 | Philips SA920017 MP3 Player
Philips PSS110/17 MP3 Player Logo
509 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
