Question about Kenmore 24 in. 15689 Built-in Dishwasher
Soap dispenser does not open every time
The dishwasher is about 5 1/2 years old. It used to open normally, but in the last three months it has not done so hot. About every other to third cycle it doesn't open the soap till the dry cycle. I was using powder detergent until about 2 months ago I switched to a liquid to see if that would fix it. It worked for a month and started not opening again. The manual was not so much help - can I replace a catch or another part?
  • Kenmore Master
  • 12,061 Answers
The spring that tensions the lid is broken or otherwise not working. I would look at the hinge side of the dispenser and see if spring is still intact. When you release the lid, it should snap open without much difficulty so if it doesn't do that, then I would suspect the spring.
Posted on May 12, 2010
jsrock516
  • 5911 Answers
SOURCE: diswasher not rinsing properly
You may have a clogged wash pump, resulting in low water pressure. This may not be enough to drive both spray arms at the same time. This can also be causing the problem with your detergents not being distributed properly. An easy way to tell if you have good water pressure is to open the door slightly while its in mid cycle. Look for a good strong spraying action from both spray arms. If you're not getting enough water, and you've already checked your supply hose coming in, then suspect you might have an obstruction somewhere. Most cleaning problems can be attributed to something as simple as food particles stuck in the vicinity of the wash pump inlet. You will have to remove the lower spray arm and coarse screen to get to it, however. Rule of thumb: If you still have to chew it, then it shouldn't go through the dishwasher. Scrape your plates of food particles, yes. But, don't put things like meat scraps, popcorn kernels, chicken bones, orange or lemon seeds, beans (the skins can clog the drain screen), etc. This does not mean you have to pre-wash BEFORE you wash. Most dishwasher detergents require the oils in foods to help activate the cleaning agents. One more thing: City water - stick with liquids or gels. Well water - stick with powders. Now, if all else fails ad you've checked the inlet to the pump and it's clear, you may have a bad drive motor and pump. Go with the cheaper solution, first. I hope this helps you. Let me know if I can help you any further.
Posted on Jun 07, 2007
SOURCE: Dishsoap stays in soap dispenser
Same thing happened to us. We noticed that it happened if the soap was left sitting before starting the washer. Since then, we immediately start the washer after putting soap in it and the problem appears to have gone away.
So much for the delayed start features, but at least the soap doesn't stick anymore.
good luck!
Posted on Jan 03, 2008
  • 1073 Answers
SOURCE: i have a kenmore dishwasher.
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Posted on Apr 10, 2008
  • 126 Answers
SOURCE: Whirlpool Gold Quiet Partner IV issue with soap dispenser
I'd check the spray arms it may be there is not enough water or the wataer is not getting where it needs to be to disperse the soap. that is where I'd start.
Posted on Jan 16, 2009
  • 423 Answers
SOURCE: After the dishwasher runs there is a lot of soap
With the LG LDF6810 model, this is not a common problem. Please try the following test, With and empty dishwasher, add a small to normal amount of dry dishwasher powder and run an (empty) load.
Check to see if any soap remains in the dispenser cup.
If any remains, here are three things to do: 1.) Upgrade your dishwasher detergent to a name brand powder (e.g.: Electrosol or Cascade)
2.) When you load the dishwasher, do not place large items in the front, near the door/soap dispenser.
3.) Before you load the dirty dishes for the next several loads, with your hand, turn both the upper and lower wash arms so they point at the door. Load as you normally do and push the racks fully in. Before you close the door, spin both the upper and lower arms and confirm that they spin freely and neither hits anything. if either does not spin freely, pull out the rack and arrange so the arms can spin freely.
I find that the only time I have left over detergent powder is when the wash arms do not spin freely.
This is a common problem on most every energy star/water conserving dishwashers.
Please report back what you find, OK?
Posted on May 21, 2010
Fairly new dishwasher - a few months old - suddenly this week tablet dispenser doesn't open during wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Mar 21, 2011 | Dishwashers
White residue left behind. Glasses come out pure white! had dishwasher for yr. and half and worked great! Now the last few months this white film is left and dishes are not coming out as clean. I use a...
heatman101
Oct 26, 2010 | Whirlpool Dishwashers
Soap dispenser does not always open
You should only need to replace the soap dispenser assembly.
Aug 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
You have a water supply problem. If you don';t get enough water then the dishwasher pump cannot pumpit up high or strong enough to dissolve the soap[. Your water valve screen may be clogged.
Apr 07, 2009 | Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Soap dispenser won't open
make and model are critical there are so many different types of dispensers that it is impossible to help you without this info
Apr 24, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Kenmore 24 in. 15689 Built-in Dishwasher Logo
192 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
