Question about Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black
New frige We just had samsung delivered today. Won't cool off and keeps beeping 11 beeps every minute.
  • 401 Answers
CHECK YOUR DOOR SWICHES AND WIRES. IF THEY REMOVED THE DOORS THE WIRES TO THE SWICHES ARE UNPLUGGED.
Posted on May 12, 2010
My samsung frige, french doors keeo ringing
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Mar 19, 2015 | Samsung Refrigerators
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
My new Panasonic microwave will not stop beeping.
Take it back to the place of purchase, this is a manufacture issue.
Mar 24, 2012 | Panasonic Microwave Ovens
Refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
802 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
