Question about Olevia Televison & Video
My Olevia LCD 226-S12 is on and my cable box is on, but it reads "No Signal" on my set. I do not have a remote but can access the source and menu buttons on the tv set itself. I cannot get a picture to come up. Please help
  • 8,197 Answers
To get the tv signal you need to press the source button till you get the signal. Push the source button once then let set on that input for 30 seconds to let the signal come in. If you do not have source on that one then push again to go to the next source. You would want the source on TV if you are using the coaxial cable.
Posted on May 12, 2010
  • 9 more comments
  • Jyackle5
    Jyackle5 May 12, 2010
    If you have any questions please ask. Also if you need you can get tne manual on the link below.
    http://www.managemylife.com/mmh/owner_ma...
  • copnik1 May 12, 2010
    Mr. JackalI. Please, please troubleshoot further - I am slowly decaying from television-deprivation. I went through every choice available through the source option: composite, S-video, component, VGA component, HDMI, Tuner (under the tuner option the message reads no channels in list). For the other 5 option it still just reads No Signal. Any help? I appreciate your input and advice. Thanks
  • Jyackle5
    Ok please hold as I look something up for you.
  • Jyackle5
    Ok hit the menu button and see if you can do a chanel search. You will want the Tv on the tuner mode.
    I appreciate the research you are doing. unfortunately, when i set the source to turner mode and attempt to change channels, a message appears at the bottom of the screen that reads No Channels in List. Please keep looking...I have faith in you!
  • Jyackle5
    Still looking. Have you looked at the manual to see how to do a chanel search.
    No - but I will do so now. but I have a gut instinct that I am the more technology-challenged out of the two of us. but I give it a shot... thanks for researching.
  • Jyackle5
    Page 32 of the manual tells you how to do a chanel search. but you want the tv set to chanel 3. Can you put the tv on chanel 3 with the buttons on the front.
    oy, no I can't and that's the problem. I am trying so hard not to blow $40 on a remote. When I set the source to Tuner and try and change channels with the channel+ button, a message appears that reads No channels in List. Gosh, there just has to be a way. Please keep researching and I will check out page 32. Thanks!
  • Jyackle5
    Ok if that does not work I am at a loss. I would have to think the input board went out on you.
    Thank you for trying.
What do I select for source if hooking up pc to use tv as external monitor
It will depend upon what type of cable you are using. Many of the units will have a PC input. Best way is to wire it up, and then go through each input until you get a signal. Remember to set your computer up for an external monitor before you start searching for the input.
Mar 17, 2015 | Olevia 26" 226-t11 hdtv widescreen lcd tv...
We get a black square on Fox and one children's cartoon network only. I have close captioning set off on my Uverse box menu. Is their anything else I need to do on the Olevia setup menu to eliminate the...
This is most commonly caused by the use of a Closed Caption text box. This type of Closed Caption is not always supported by the broadcaster, and results in the appearance of a black rectangle with scrambled or no text.
This can be quickly resolved by adjusting the Closed Caption type to "CC1" or by disabling the Closed Caption feature on your television.
get in the menu and change the close caption with the Olevia remote control
This should fix you right up
Dec 03, 2010 | Televison & Video
I need the remote code for an Olevia 237-S12 tv for my Comcast cable remote.
Olevia was never big enough to be given any codes by the cable companies or the box manufacturers. What I finally did was buy a Logitech Harmony remote online. The price range is pretty broad depending on the feature set you're looking for. But if you're fed up enough it will get the job done for anywhere from $40 to $100+.
Nov 29, 2010 | Olevia 237T 37 in. LCD TV
Received used Olevia 226-s11 hdtv, hook-up up (no
I need to go to Menu, Picture, Mode, Home.....
The default setting for the TV was Showroom which wouldn't let the cable signal through. Thanks for trying to help.
Jan 12, 2010 | Televison & Video
No signal when cable is plugged in
check your input make sure it is set to catv (cable)
Oct 20, 2009 | Syntax Olevia 432V 32 in. LCD Television
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
No channels
Are you using a set-top converter box?
Jun 30, 2008 | Olevia LT32HVE 32 in. LCD Television
Olevia 432 s12 remote codes for time warner
the answer that you seek...is already in your hand
search the web for manuals? seek a helping hand?
flip over your remote control...and open up your eyes!!!
read the battery cover then slap your head for you've found where the secret lies.
~em
Mar 14, 2008 | Olevia LT42HVi 42 in. LCD Television
TV tuner
Bill, did your tuner go out? I have had the same television for one year. We had a storm and our Buckeye cable went out. All the other tvs came back fine except for the room with the Olevia 232-S12. Everything works now except for the tuner. Cable came in and installed a converter box. Just wondered if you had the same problem (not the storm, but the tuner)
Jan 08, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
112 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
