Question about Homelite Mighty Lite Lawn Trimmer
Can't adjust carburator.
How do you adjust carburator on homelite mighty lite model ut21546a?
    Problem Solver:
  • 7 Answers
Look on the carburetor. there will be 2 screws right beside eachother. one is an idle jet and the other is the main jet. if you want faster or slower idle speeds, adjust idle jet. if you want more power, adjust the main jet. you have to get them set just right . they might smoke a little bit because you are throwing more fuel to it which means you are getting a richer mix
Posted on May 12, 2010
How to adjust a home lite mighty lite blower vac carburator "?"
Hi. This link,
http://manuals.homelite.com/documents?page=5
is to the homelite page where the manuals are, however, there are 4 different models of the handheld blower you have. Either way, if this is a really new model, there may be no way to adjust the carburetor, as due to emissions standards, there may not even be any idle screws, but if they do exist, the head ma be whats called "pacman", as it looks like a little....yeah...pacman.
Apr 25, 2014 | Homelite Mighty Lite Blowervac
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Nov 10, 2012 | Homelite Mighty Lite Blowervac
I just need a manual for the Homelite Mighty Lite Gas Powered Blower Vac.
Do you have your model number?
You should be able to find your manual on this site:
http://www.homelite.com/service_support/product_owners_manuals
The manuals are listed by their model number rather than their marketing name. Look for the serial number plate which should also have the model number.
Thank you for using FixYa!
Aug 26, 2011 | Homelite Mighty Lite Blowervac
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
WILL NOT STAR PULL AND PULL WITH NO RESULT
Have you replaced spark plug and fuel filter? I have a Homelite Easy Reach, and after tuning it up, it still would not start. I had to do some modifications with a utility knife to get access to the carbureator adjustment screws. I was able to cut away a piece of plastic that made the screws "tamper proof", exposing the adjustment screws. Then I turned both screws clockwise all the way in, and then back out 2 turns. After doing this, I could get started and make further adjustments. Do you know if you have plastic or metal around adjustment screws on your trimmer? If metal, you can use a hack saw to cut grooves in the adjustment screws so you are able to turn them in and adjust. Hope this helps
Apr 23, 2011 | Homelite Mighty Lite Lawn Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Is there a carburator adjustment on this?
yes there is two screws that set the carb up,,,one is the slow running screw the other is the fast rev set up screw ,,,set the slow running one up first
Jun 24, 2010 | Homelite Mighty Lite Lawn Trimmer
Carburator adjustment
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .EACH SCREW SHOULD BE 1 1/4 TURNS OUT THEN YOU WILL NEED TO FINE TUNE IT FROM THERE. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Jun 23, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
789 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
