Question about Kenmore 45081 Front Load Washer / Dryer
The drum is loose, it moves forward and backward and up and down. I can see daylight in the rear. I am puzzled. I removed the back galvanized panel and a couple of wrong screws that hold the panel with the heating element. Suggestions? It looks like the rear panel somehow isn't right because that is the only one that can move, I also removed the the front panel and the one behind it to clean it out.
jsrock516
  • 5911 Answers
SOURCE: Kenmore front loader
There's no easy way of getting something out of between the tubs without removing the rubber door seal from the tub. It's a pain in the rear to get it to go back on too, because of the retaining spring that holds it in place. Are you sure the screw is between the tubs and not stuck behind one of the was tub fins? Most small items like screws will eventually find their way into the drain line and get caught in the drain pump strainer. Since you can't see the screw, it may actually be trapped behind one of the fins. One way of knowing is to roll the inner basket with one hand and listen. If you hear something rattling around it's somewhere in or on the inner tub. The outer tub (or shell) does not move. You can also look through the inner tub holes with a flashlight while turning it slowly to see if you can see anything between the wash tub and shell. Usually, water and gravity will force anything lying in the tub shell into the drain line. Let me know if this helps you.
Posted on Jul 07, 2007
Krazytech
  • 725 Answers
SOURCE: Leaking : Heating element come loose from Drum
The nut in the center squeezes the rubber gasket and should seal the heater in place Hope it helps
Posted on Sep 07, 2008
SOURCE: HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Posted on Jan 19, 2009
  • 686 Answers
SOURCE: Adjust motor/heating elem to put screws back - Kenmore Dryer 417?
pull them away from the wall and see if you have an access panel in the rear of the dryer. If you do remove it and undo the belt so that you can freely sway the drum in either direction. it may re-align the holes for you to replace the screws if not you'll have to open the dryer possibly by prying the top up and undoind the screws that hold the front panel to the cabinet. from there you should be able to move the drum about to get the scres back in but f you do get it opened take the time to clean it out. Make sure you undo door switch wires before removing front panel.
Posted on Apr 03, 2009
  • 16 Answers
SOURCE: the heating element( I'm guessing) inside the
last thing u wanted to do was remove the three middle srew they hold the drum .
u are going to need someone else to help,first try to reinstall the srews .
after reinstalling
top left back there is a thermal fuse this fuse goes when the element goes element about $95.00
fuse 13.00
under neath the panel next to timer 1 black screw on other side 1 more screw remove
remove casing with both timers.more screws
un clip all wire harness
all screws on top off
look at belt remember how it came off
now remove front panel
remove belt
push up drum hard
remove drum
now u can get too the heater
best of luck al
Posted on May 13, 2009
How do i take the back off on a 1999 nissan maxima bucket seat
Hi, follow the instruction below......
Rear
See Figures 3, 4, 5 and 6
  1. Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
  1. Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
  1. Remove rear seat back by tilting forward and pulling straight up.
To install:
  1. Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
  2. Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
Jan 19, 2011 | 1999 Nissan Maxima
I have a 2004 chevy aveo. the rear driver side brake is locked. can not turn tire. how can I get the drum off. am having a lot of problems
you are going to have to access the hole in the back of the hub with a screwdriver and back off the self adjuster.
The inside of the drum looks like the below pic. The adjuster is the long horizontal cylinder above the axle. It has a gear on it. Stick your screwdriver in and turn the gear until the drum loosens.
Oct 06, 2010 | 2004 Chevrolet Aveo
I've changed the drive belt, but it seems that the...
If the drum being pushed forward makes the problem better, I would say your felt pads under the drum which the drum rides on are either worn down the metal or loose.You need to remove the front casing of your dryer and inspect these felt pads. If they are loose tighten them up and if they are worn they need to be replaced. When you have your dryer apart you may also want to try to move the rear of the drum to the left and to the right and see if the back of the drum is loose as this means your bearings are loose and may need replacement. To fix this problem however the top of your dryer will have to be removed to take the drum out (many times the top will tilt back on hinges) because the bearings are on the back of the drum.
May 12, 2010 | Dryers
CLUNKING NOISE WHEN SPINNING SAME SOUND WHEN TURNING MANUALLY
Have you tried turning the drum with belt removed to see if sound is from drum or motor.If you cant get at belt easy thru. top ( make sure power is off) then you will have to split the casing which will give you a great view of all the moving parts to see if any loose parts.It may be that the bearings have gone so badly that it is clunking as it turns.Normal bearing failure noise is a rumbling.
Remove 2 screws at rear underside of top lid and remove.On top middle either side by springs remove the 4 screws holding back panel,down below at rear there is normally 2 or 3 screws on corners of panel,now go to side of panel bottom middle by seam and remove round white plastic covers put small screwdriver in hole and pull out there is a screw behind each (8mm small socket).Now by water inlet valves prise out white plastic housing with valves still inside now put screw driver in spli on side panel either side and work it back you will have to hold down drain hose to clear panel,once off you can inspect for any damage or loose parts,check drum pulley is not loose or worn,check motor also concrete balance weights one on back top of drum casing and one at front around door seal,sometimes these come loose.To refit casing it is a reverse of removal.
Hopefully this will be helpful.
Good Luck.
May 05, 2010 | Zanussi FLA1001W Front Load Washer
I need a manual or somebody to tell me how to remove the back of my hotpoint dryer. Model DLL2650BGLWH. It sqeeks really bad and I was told it's prbably a shaft or bearing. Also, can I just try to...
Disconnect power to dryer.
Take screws out above door, allowing dryer top to swing up and back.
Remove screw near top from side panel into front panel, allowing front panel to be removed and set to the side.
Some models have a very small access panel at the very center of the drum on back, which may hide an " E " clip on the drum shaft, which would have to be removed, all other dryers no longer use them. Lift dryer drum up slightly and pull it forward a couple inches. (you do not need to remove the belt) Remove all the loose washers / sleaves on the back shaft of the drum and install a new WE3X75 rear drum bearing, then re-install drum. (no need to put the E clip back on.)
Check the drum slides on the bottom front side of the drum. Most times, if the rear bearing is in need of replacement, so are the front drum slides, especially the one on the left (blower / motor) side.
Just trying to lubricate it will not solve your problem.
Feb 18, 2010 | Dryers
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
How do you get the heating element out of a dryer model GLER341ASO Serial X013305567
Disconnect power before working on this dryer.
Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior.
The heater is located behind the drum on the back wall. Disconnect the belt through the small opening at the rear of the dryer. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Lift drum about 1 inch straight up at rear...then pull whole drum forward while keeping lifted. This should expose the heater for checking.
Reverse process to re-assemble.
Oct 02, 2009 | Frigidaire Dryers
Our Maytag dryer runs, but the drum is not moving. When I try to spin the drum it won't hardly move backwards and forward it is hard to turn as well.
Check your blower wheel for a lint buildup or other obstruction.
Remove the front panel to access the blower wheel.
Mar 03, 2009 | Maytag MDE9700AYM Electric Dryer
Off balance, loose drum?
If your machine produces a lot of banging noises when in a permanent press final spin you may be experiencing a broken spider. It is a part which is not made from stainless steel metal, but attached to a stainless still drum (tub spin). So, when it is soaked in water all the time during a normal operation of a washer it creates a galvanic element between a stainless still drum and itself. This results in severe corrosion of the "spider" and then leads to it's breakage. To check if you have a broken "spider" open the door of the washer and try to kick your internal drum back and forward while rotating it slowly.If you will hear clicking noises (metal to metal) in some position of the drum it means that your spider is broken. The replacement of this spider will require complete disassemble of the drum. Most likely you will end up replacing this whole part
Drum assembly, spin basket Part # 131618500Another way is get just a spider part, it's doable, but may be tricky.
Cheers!
Oct 29, 2008 | Kenmore 44042 Front Load Washer
Creda
remove the rear panel screws, remove side panels, pull drum backwards, slide belt down front of drum and under, refit rear panel screws refitting drum at the same time, place belt around motor spindle and reasemble, job done.
Dec 24, 2007 | Washing Machines
Kenmore 45081 Front Load Washer / Dryer Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
