Question about Lexmark X2600 InkJet Printer
The black ink cartridge is not empty but it won't print anything black. Will print colors.
  • 39 Answers
Probably your ink cartridge is clogged. Try to clean it first by using your printer cleaning software. If it does not work, take out the black cartridge clean the portion where the ink is coming out using a cotton and a cleaning solution (water and alcohol will do). Repeat the procedures if necessary.
Posted on May 12, 2010
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
Sep 26, 2007 | Epson Stylus C66 Inkjet Printer
Lexmark X2600 InkJet Printer Logo
154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
