Question about Dell Office Equipment & Supplies
Own dell 3000cn. paper jam. wife was using. instead of pulling paper through, she tore it off at the roller so that it is impossible to get a grip on the remnant of paper inside the roller in order to remove it. don't know what to do next. can you help?
  • 2,427 Answers
Yeah... See the gears on the roller... Roll them back using a bladed screwdriver to get the paper our.. The gears are at both ends of the roller... If that fails you will have to open the printer out... And the gear mech should now be exposed... Simply pull the paper out now that u can see it... Ps.. You can also roll the roller to give some extra. Grip
Posted on May 12, 2010
Cannon pixma mx922 paper jam
I had a very bad jam (paper tore...you know the drill...see upper panel). My wife and I used a chopstick and hemostats to gently, gently lift the rollers and ease the paper out (lower panel...most of the paper has been pulled out). The stick should be applied to the support between the rollers. You have to go from roller-pair to roller-pair, easing the paper out without ripping it.
Oct 14, 2013 | Canon Office Equipment & Supplies
Dell 3000cn Laser Printer Problem--Paper Jam
Have you been able to get the toner out yet?
There is a little handle on the right side that you need to lift to unlock the cartridge:
See if there is anything hiding in that part of the paper path. Maybe even just re-seating the cartridge will be enough for the sensors to stop tripping.
Feb 13, 2008 | Dell 3000cn Laser Printer
I have a Dell 3000cn and it won't print due to the problem "Paper Jam Open Reg Cover." I have tried looking for a lodged paper inside the printer, and trying to let the roller read the paper. Any...
I've got the same problem.
The problem is probably due to a lose or defective sensor.
Open the back cover. In the middle you can see now a sensor (2 small glass "eyes". It is possible that this sensor has lost connection (white plastic holder). The way to access this is to open the imaging drum cover, remove the drum and reach all the way down inside.
So far my theory. I can not reach it and have little hope. Never again a Dell :-( .
Jan 06, 2011 | Dell 3000cn Laser Printer
Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Aug 06, 2009 | Dell 3000cn Laser Printer
Error Message - Paper Jam
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Feb 25, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper not loading and getting jammed
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 06, 2009 | Dell 5100cn Laser Printer
Paper Jam 075-134 (states Open Reg cover and Check MPF)
The problem might be that it isn't picking up the paper. This will register as a jam if the paper does not reach the next paper sensor within a certain amount of time. check the feed assembly and check the paper to see if there are any marks on the edge from the pickup roller.
Dec 28, 2008 | Dell 3000cn Laser Printer
Paper not feeding
The Dell 3000cn & 3010CN both display this fault.
The root cause of the problem is the Rubber pads of the feed roller in the paper tray become warn and fail to grip the paper the paper feeds a few millimetres and then is let go by the worn roller, the paper path sensors pick this up and then a paper jam is notified.
The only remedy for this problem is to obtain a new feed roller for the paper tray mechanism. Unfortunately dell in the UK do not sell maintenance kits to the public, and therefor ehte only place I found them wa on Ebay in the USA.
The kit in quetsion is the vertical paper feed maintenance kit. it costs around $50 plus shipping.
The only other option is to have a Dell approved service agent replace the rollers for you.
If you hear a grinding or cruching noise when paper is fed, then one of the mini plastic guide rollers had detached itself from its position and wound up in the tape path mechanism (very expensive repair)
Jul 12, 2008 | Dell 3000cn Color Laser Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
18 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
