Question about Whirlpool Dishwashers
Clean light flashes 7 times - Whirlpool Dishwashers
    President:
  • 949 Answers
This is due to the water not being heated properly. I have put together some instructions on what to look for and how to reset the control so you can use the dishwasher again.
Follow the link and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 12, 2010
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Apr 29, 2014 | Dishwashers
Whirlpool/Honeywell hot water heater light flashes 5 then 7 times and won't light. Burner is clean and all contacts are good. Out of warranted.
Copy following link to troubleshoot by type of gas control valve, including directions for cleaning air intake screen, and or replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7 flashes: Gas control valve might be bad.
4 flashes: FV overheat, clean air intake.
Soot indicates clogged air intake slowed combustion venting possibly causing overheating and lockout. Clean air intake screen located on bottom of unit.
Apr 17, 2013 | Water Heaters
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher is locked out. Clean light flashes 7
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Kenmore 17024 Built-in Dishwasher
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Clean light flashes 7 times then repeats
Bonjour,
ma machine à laver la vaisselle., Maytag, le modèle S-MDB9600AWS PLASTIQUE éclaté sur les deux roues tiroirs connectés navires. Où puis-je acheter ces roues et ce que nombre d'entre elles ont?
Merci,
Aug 17, 2009 | Kenmore Dishwashers
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Dishwashers Logo
46 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
