My playstation says the hard disk's file system is corrupted and will be restored. and i followed the instructions multiple times and it still shows the same screen how do i fix it ?
Re: My playstation says the hard disk's file system is...
You will need to replace your HDD with another new one. Install that new HDD and then perform the recovery procedure.
www.gamespot.com/features/6176090/index.html www.videojug.com › ... › Video Game Consoles › PlayStation 3 - boardsus.playstation.com/t5/PlayStation...Hard.../28102378 Links above show you in tutorials what to do and how to do it.
You
could attempt to boot up the PS3 in safe mode and restore the file
system (should delete any corrupted data). Describing how to start up
your PS3 in safe mode would just be confusing, so instead here's a link to the official page on the PS3 Safe Mode feature.
Follow
the instructions, and then I'd say try options 3 (Restore File System).
If that doesn't work, try 4 or 5 (Rebuild Database or Restore PS3
System).
If that fails, you could just replace the hard
drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives
(5400 or 7200 RPM). They can be found online at any computer parts
website; for example, Tigerdirect.
If somehow the new hard drive doesn't fix it, or you don't feel like buying a new hard drive, you could send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe).
If you request the repair service, they send you a box, you put the PS3 in it and ship it back to them. A month or 2 later they send you a fixed/different PS3. Simple, but takes forever to get a working PS3 back which is why I suggest you try a new hard drive first.
faulty hard disk, the only option is to replace it with a new one. bad news, you lost all your data, when this happens, make backup of important data next time.
Be sure to folleow these instructions to the letter, you could damage your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”. You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options
1. Restart System: Restarts the PLAYSTATION®3 System. 2. Restore Default Settings: Reset all system settings back to default. CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files. 4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3. 5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch. 6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive isoption 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen. www.youtube.com/watch?v=m0SPmkV-jco If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash
Hi if you have the ps3 with the model # cechh01 or cechk01 or cechl01 this happen a lot you need to install the new update in a usb memory card and follow the instructions on the ps3 go to sony for instructions on how to download the update in a removable usb if you have the older models you need to format the hard drive or install another one and format the old drive in another ps3 and this can fix your problem
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best! P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
If you have tried it a few times it may be a damaged HDD. You can do two things. Buy a new HDD (2.5 inch SATA drive) or contact Sony and see what they have to say.
