Question about HP cp1700 Color Inkjet Printer
My HP CP1700 prints out gray tones in pink.
When running cadd prints my HP ink jet printer began printing gray tones as pink. ( I was getting the grays until recently.) The ink cartridges show to be full.  How do I get accurate grays?
  • 2 more comments
  • warrenlawson Mar 29, 2008
    I did this procedure successfully, ran a diagnostic report: all cartridges and print heads look good. Also ran level 1 & 2 print head cleaning procedure: now there's no gray at all when printing.
    Cadd prints on HP CP1700 are coming out with pink areas where gray tones should be. I ran a level 1 & 2 Print head cleaning procedure and had the printer print out a diagnostic report. Results: print heads and cartridges are shown to be good, but, now, the pink is gone, but along with it, the gray tones as well. How do I get accurate grays?
  • warrenlawson Mar 30, 2008
    Ink cartridges are HP, expire date: 12-3-09; not refilling them myself; printer is 3 1/2 years old...haven't used it much, mostly in last 8 months; print heads are original-installed date: 9-16-04.
  • 4,102 Answers
Hi the usual course for this problem is using generic ink sometimes they can cause this problem.
If you are using original let me know also are you refilling them yourself and also how old is the printer????
Posted on Mar 29, 2008
  • 818 Answers
Maintaining the printer body Printer case exterior Follow these guidelines when cleaning the outside of the printer:
  • Use water only. Do not use household cleaners or detergents.
  • Use a soft damp cloth to remove dust, smudges, stains, and spilled ink from the printer case exterior.
Printer interior Do not clean the printer’s interior. Keep all liquids away from the interior. Print carriage rod Do not lubricate the rod on which the print carriage moves. It is normal to hear noise as the carriage moves back and forth on the rod when the printer is new. Handling and storage Handle and store the printer in an upright, level position for maximum performance and reliability.
Posted on Mar 28, 2008
  • Anonymous Mar 28, 2008
    This document explains how ink stains can be
    removed from hands and fabrics.
    How to remove ink stains
    NOTE:
    IMMEDIATELY rinse the stained area with
    cold water, then follow the appropriate
    instructions.
    How do I remove ink
    stains from my hands?
    Wash hands with an abrasive (gritty)
    soap.
    How do I remove ink
    stains from white fabrics?
    If ink from an HP Inkjet print cartridge spills on
    your clothing, use chlorine bleach and cold water to remove the stain.
    CAUTION:
    Use cold water. Warm or hot water will "set" the color
    into the fabric.
    How do I remove ink
    stains from colored fabrics?
    Ink from most HP print cartridges should wash out
    with sudsy ammonia and cold water.
    CAUTION:
    into the fabric.
    WARNING:
    Do not mix ammonia and chlorine bleach; this creates a
    toxic gas
  • Anonymous Mar 29, 2008
    remember to rate us.
    Sergio
  • HP Master
  • 19,396 Answers
Your head / nozzles must be dirty , perform a nozzlecheck /head clean from printer software maintainance utility,
regards
SOURCE:
Printer does not print in color but only prints in
Run a "print-head-cleaning-cycle" -- the ink inside the cartridges is not getting through the ink-jets, and is not reaching the paper.
Either that, or the electronics inside the ink-jets are malfunctioning, i.e., not telling the ink-jets to shoot the ink out.
Jul 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
My hp 712c printer prints only the pink band when I run a color test. I have replaced the original cartridge. Any ideas about the cause and solution.
The cause is either:
* clogged ink-jets not allowing yellow & blue ink to move from the ink-cartridge onto the paper;
* busted electronics inside the printer, causing the ink-jets to not "spray" at all.
Use the software to try a "print-head-cleaning" cycle.
If that fails to improve things, it's time to replace the printer.
Jun 24, 2010 | HP DeskJet 712c InkJet Printer
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
Can't print BLUE.
I use a clear silicone tube to carefully prime the carts by sucking a dab of ink out of the tiny print holes before installation. I am careful to have a tight seal at the holes to prevent getting too much ink and possibly getting it in my mouth. Make sure each color appears.
Jun 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP CP1700 - no cyan or blue printing
Try taking a look at your printheads. Have they been installed for some time. You may need to change them. Start with the Cyan first.
Inkworks
866-381-0541
Oct 24, 2008 | HP cp1700 Color Inkjet Printer
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Jan 04, 2008 | HP DeskJet 950c InkJet Printer
Colour???
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Oct 25, 2007 | HP DeskJet 450Ci InkJet Printer
HP cp1700 Color Inkjet Printer Logo
211 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
