Question about Frigidaire GLER341A Electric Dryer
Noise the dryer makes a lot of noise when running. Sounds like its ready to blow up
  • Frigidaire Master
  • 8,220 Answers
The rear bearing will eventually fail and drop the drum into the heating element. You need to inspect the innards. Here is a PICTORIAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 12, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer makes loud whirring noise when try turn on, won't start
I am guessing that it does not do anything after it makes the noise?. If you hear something running after the whirring noise, but the drum is not turning it is possible the belt has broken or slipped off the motor pully. If you hear no noise after the first startup and it completely stops making any sounds then it may be a motor problem. I am no pro, just a do it yourselfer. www.repairclinic.com can help ya more than me. Just have the model number ready when you go there and look at the symptoms. Hope this helps.
Oct 11, 2014 | Dryers
IGNIS dryer makes too much noise
idler wheel bearing probably shot. if you can get the back off, you should be able to see the wheels on the bottom sides of the drum. they are just held on with a bolt. may be able to find parts on line
May 14, 2012 | Dryers
My Neptune dryer makes a lot of noise while running sounds like bearings rattling what do in to do to fix?
the problems could be many. agreed its something that moves from your description.
moving parts are
motor, belt, drum, drum rollers (or glides but they dont move) could make noise if so equipped), fan in housing going to heater.
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Maytag Dryers
Whirlpool gas dryer makes a lot of noise
This sounds like the support rollers are either loose or worn out.
Turn off the power, shut off the gas, pull the unit away from the wall carefully, and remove the back of the dryer.
Look around the perimeter of the drum and you will see the rollers. There should be 3. If they wobble or the rubber on the rollers is worn down, they are bad and need replacing. While you're in there, inspect the motor, belt, and drive assembly to be sure it's solid.
An appliance shop or parts outlet can usually provide these parts for your unit.
Jan 28, 2010 | Dryers
My whirlpool dryer will run full cycle when empty but not when loaded, it stops and each time i start it the time it runs is less and less
sounds like you have a bad motor, does it make a noise like a buzz sound and it just sits there,overloading can do this and another thing that kills them is when they get covered with lint and dust,when was the last time you cleaned out the dryer?you should clean it at least once a year,you gotta clean out the duct that the lint filter slides into,vac out the inside of the dryer where the motor is,a shop vac works great because they blow air on one side and **** air on the other,blow off the motor and blow the lint from the back to the front so you don't have to pull the drum,then clean out the vent line,if it's a long run blow it out with a leaf blower,alot of people don't know that the dryer has to be cleaned out like this,could have a fire!you can check the pulley and the rollers but sounds like the motor
Jan 20, 2010 | Whirlpool Dryers
Dryer makes loud sound while running sounds like a bearing
a lot fo things cause noisey dryer . ( look for wire clothing stays in drum/ pins in the felts back and front. or dad may have left a sheet rock screw in his pocket . or a key / these things we take out of dryers every day . look hard . i think you will find some thing .. slow sounding noises are related to the drum . fast and hi pitched noise repate to motor and drive componet's .. mm
Dec 12, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer makes a lot of noise and sometime stops
yes the rollers can wear down and make alot of noise I believe there are 2 on yours.
Jan 13, 2009 | Amana Dryers
Frigidaire GLER341A Electric Dryer Logo
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
