Question about Brother Office Equipment & Supplies
I changed me toner cartridge and it ran out quick
I changed me toner cartridge and after about a week it said it was low again and wouldn't print. Isn't it supposed to last longer than that?
  • 240 Answers
Hello
The toner cartridge yield varies depending on the cartridge but should print something about 1500 pages for normal cartridges or 2600 for high yield.
If you only printed about 100 or 200 pages your cartridge might be defective or did not reset.
You should call brother, they can check the serial number to see if the cartridge is defective or not. 1-877-brother for free lifetime tech support
Thanks,
Pat
Posted on May 12, 2010
Brother HL 3070CW says the toner is low and won't print. It has toner and I have to get something printed for a client
I done on my brother lh3070cw printer cartridge on Message "Low Toner"
First I take off toner cartridge
second - Covered the both Glass Buttons of Cartridge situated right and left side of cartridge (all cartrideg) for Black Electric Tape.
thent install the cartridge in the printer again.
after install the cartridge press SECURE PRINT AND CANCEL BUTTON SAME TIME AND CLEAR THE STR AND STD FOR PRESSING ok BUTTON FOR 2 TIME.
ERASE EACH STR AND STD
THEN PRESS CANCEL
YOU CAN USE YOUR PRINTER FOR END OF THE TONER
Mar 28, 2011 | Brother MFC-9440CN Laser Printer
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Sep 02, 2009 | Brother HL-2040 Laser Printer
Faded prints about 2" in from the margin
Greetings!
{You used the term "drum". This may indicate a roll type of toner rather than a cartridge style of toner. The following tip is for a cartridge style.}
I get much the same symptom when my HP laser cartridge is running low, and no, it doesn't have a "low toner" indicator either. I get by a little longer with mine, long enough to get out and buy a new one that is, by removing it, holding it over a garbage can at an angle and firmly tapping on it to loosen any compacted toner. I then turn it back horizontally and gently shake it back and forth to evenly distribute the remaining toner through the cartridge and reinsert it into the printer. This usually gets me nice, even prints back and extends the life of the cartridge. I can usually get a few extra weeks out of it by doing this two or three times.
Rob
Jan 14, 2009 | Brother IntelliFAX 4100 Laser Fax
CopyCentre C20 Toner Low Stays On
ave you tried shaking the cartridge vigorously from side to side?
The ink may be compacted in one end of the cartridge from storage.
Jun 06, 2008 | Xerox CopyCentre C20 Black and White...
Blank trace appears on printed copy
replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Jan 07, 2008 | HP LaserJet 1020 Printer
Unisys UDS 25 Printer Problem - Identical to Lexmark T614
check the Technical Support Team for this machine My guess is the drum is on its way out - or some other replaceable control item but they will know.
May 25, 2007 | Lexmark Optra T614 Laser Printer
197 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
