Ink system failure
I have an HP Photosmart 8250 and I recently had to change the yellow ink cartridge. Well, ever since then, I get the message "Ink System Failure, refer to printer documentation". ERROR 0xc18a0001. Then it tells me to turn the printer off and on .. but it still doesn't work.
I have a Photosmart C6280 that got the error 0xC18a0001 with "Ink System Failure" and nothing I tried would fix it. Called HP Support and they said there were lots of things that could cause this. Checked to make sure I had HP cartridges first, which they were (from Walmart). Problem was escalated to a senior tech on phone. The secret sequence on this printer was press both Print photo and RedEye buttons then RedEye then PrintPhoto then RedEye which would get you into the Support screen. From there right arrow to system config the ok then hardware error then ok then clear okay. Power off and it reset the error condition. If you are under warranty then call HP support it is worth it. If not, then navagate the support screen carefully. Hope this helps the next guy. cheers...cgb
  • 1 more comment
  • janeymca Mar 02, 2009
    To Glenb22 - I tried everything to fix my C6280 with same "ink system failure" error. Followed your instructions which worked! Thank you so much for taking the time to post this solution. You saved me time and money as I was on the point of taking it to an HP centre. Cheers Jane
  • Anonymous May 07, 2009
    thanks! with your information I fixed my printer ¡Thanks! you are an angel
  • Andy Serrao Mar 16, 2012
    Your post is 4 years old, but it's still helpful. My HP has been down for over a week with this error message. I went to dozens of sites that gave advice. None of them worked, including HP's. Thank God I stumbled onto your solution. Worked like a charm. My printer is up and running again. Thanks, glenb22
Ok i got it...
Press and Hold the “Print Photos” &”Red Eye Removal” buttons. Release both buttons. Display should say”Enter Special Key Combo”
Press and release in sequence”Red Eye Removal”,”Print Photos”,”Red Eye Removal”
Display should say “Support” and display the FW rev: COxxFN0723BR (or something like that)
Press and release the right arrow button until the display says “System Configuration Menu"
Press and release the “OK” button.
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
print a test page:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
if this doesn't work, i'd call hp support.
Posted on Mar 24, 2009
How about...... The.. Error ! Print Cartridge "Refer to printer documentation
Posted on Aug 05, 2009
Glenb22 and Surfrdawg, this really worked, thanks so much! I called HP support and they said my printer was too old, they don't make it anymore and I would have to buy a new printer. Thanks for saving me a couple hundred dollars! God bless.
Posted on Jul 21, 2010
  • kingy27 Sep 12, 2010
    Many Thanks Glen22 for posting the solution for ink system failure on C6280 Photosmart printer, it really does work, i,ve know saved your solution, just in case i get the same problem in the future.
    once again many thanks Mark27
My hp photosmart printer c 6288 restarting problem give the solution
Posted on Dec 01, 2009
    Problem Solver:
  • 9 Answers
Simple. change the catridge. Running out of ink. hahaha
Posted on Mar 29, 2008
I get the message "Ink System Failure, to my hp photosmart c5180 all- in- one.
how could i solve this problem
Posted on Jun 11, 2008
Ink system failure have tried everything such as resetting and nothing works
Have you installed a new cartridge or tried the old one that worked to see if the new cartridge you have was bad out of the box?
Jan 07, 2010 | HP - HP Photosmart 8250 printer
HP 8250 Photosmart printer that displays "system ink failure"
Try changing the ink cartridges.
If you installed the "HP Support Toolkit" software from the CD-ROM that came with the printer, use this Toolkit to "run a cleaning cycle".
It can print a "test" page, to show you which colours _do_ work, and which do _not_ work.
If all else fails, then find a qualified printer technician.
Dec 31, 2009 | HP - HP Photosmart 8250 printer
Ink system failure. How do I reset a hp 8250 printer?
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the printer, wait for the printer to prompt that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime the ink cartridges. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Nov 15, 2009 | HP - HP Photosmart 8250 printer
Ink failure system error
1. Turn the printer off for few minutes then turn it back on
2. Clean ink cartridge
3. Update drivers
4. If nothing works, repace the battery
Sep 07, 2009 | HP Photosmart 8250 InkJet Printer
Can't print on 8250 photosmart printer
See http://www.hp.com/pageyield/articles/us/en/InkExpiration.html on how to override error.
Apr 19, 2009 | HP Photosmart 8250 InkJet Printer
Ink system failure
it could be a viros or a printer jam
Aug 16, 2008 | HP - HP Photosmart 8250 printer
Ink system failure
well nothing to say but!!! go get a new one!!!!
Jul 12, 2008 | HP Photosmart 3210 Printer
Ink system failure
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 06, 2008 | HP - HP Photosmart 8250 printer
3,662 people viewed this question
jasbo
jasbo
