Question about Compaq FS7600 17" Flat Glass Monitor
Monitor fs740 contrast is 0%, can't adjust it.
  • 560 Answers
In your monitor settings you should have a default settings selection button you can Select and it will or should set your monitor to default . If it doesn't work , you have a problem with the monitor itself .
Posted on May 12, 2010
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
Compaq fs740 text too faint and fuzzy to read well
Firstly you need to switch to the monitor's optimal resolution of 1024x768 @ 85Hz and before anyone posts anything about resolution 1024x768 @ 85Hz is the optimum not the maximum. To change to this resolution: Assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1024x768 and then click Apply. Also in Display settings you'll find an advanced button, in the advanced panel you'll see the option to adjust the refresh rate, try adjusting this to 85Hz. Now press the Menu Button on the front of the monitor and press + of - until you see an option called "Degauss" and press the select button on the front of the monitor, your screen will do a disturbing jump and flicker accompanied by a metallic thud, this is normal. If this doesn't help message back.
Aug 26, 2007 | Compaq fs740 17" CRT Monitor
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Compaq monitor FS740 is turned off after some time
Step 1:
Check your screen saver setting.
Step 2:
check your monitor setting to always in active mode.
Jan 10, 2013 | Compaq FS740 Color Monitor
I have AcerPower Series Desktop PC with AC713 Monitor. My problem is in the middle of the screen BRIGHTNESS with 0% of its adjustment go on displaying which hampers my work. Even it's not able to...
Good day,
It seems your monitor is the problem maybe the button is stuck or something. Try bringing it to the nearest service center.
Tnx.
Aug 18, 2011 | Computers & Internet
My monitor compaq FS740 is out of focus
Focus adjustment on a CRT monitor is a simple thing to do, although you need to open the case and there are HIGH VOLTAGES inside.
The adjustment is actually on the high voltage (flyback) transformer. There are two screwdriver adjustments, the one you want is labelled Focus (of course). Do NOT adjust the other one, you may destroy your monitor and injure yourself.
This MUST be done with a plastic adjusting screwdriver, NOT with a metal one. This transformer produces in the range of 25,000 volts, from the high tension lead on the top which plugs into the back of the picture tube. This lead still has very high voltage present, days after turning off the monitor.
If you don't feel competent to do this, that's fine, take it to a technician who is comfortable with it.
You have been WARNED of the dangers.
It's also possible that the lack of focus is a symptom of something more drastic being wrong, in which case you would probably think about buying an LCD screen.
Apr 16, 2010 | Compaq fs740 17" CRT Monitor
Unable to adjust contrast
http://support.dell.com/support/edocs/monitors/r83546/EN/setup.htm#Using the OSD
"NOTE: When using DVI source, the contrast adjustment is not available"
Dec 06, 2007 | Dell UltraSharp 1905FP 19" LCD Monitor
Compaq fs740
u need to go into your control panel then display settings to adjust rersolution
Aug 17, 2007 | Compaq fs740 17" CRT Monitor
CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Sep 28, 2006 | Keytec Sony Multiscan E500 21 in. CRT...
Compaq FS7600 17" Flat Glass Monitor Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
