Question about Olevia LT42HVi 42 in. LCD Television
Can't figure out how to upgrade the firmware on my Olevia LCD tv. I go to the menu button and it'll tell me what version I have but it doesn't tell my how to upgrade it.
    Brigadier General:
  • 4,090 Answers
If you have the updated firmware on CD put it in PC and connect to TV via the connection cables. The instructions for upgrading should have been supplied
with the CD
Please rate my help++++Thanks for using FIXYA
Posted on May 12, 2010
How do I get channels set up?
goto menu and channels and some may say " edit or add " that where you will do it. as long as you know the channel # it should go smoothly.
Nov 17, 2015 | Olevia 26" 226-t11 hdtv widescreen lcd tv...
How can i tell if my lg tv has the lip sync firmware fix
In the menue go to Update firmware. It will display the firmware number. reply no when it ask if you want to upgrade. Contact LG any tell them the numbers. They will tell you if firmware upgrade is current or not. They will send you the upgrade if it's needed.
Nov 22, 2009 | LG 55LH40 55 in. LCD HDTV
My olevia tv is not sensing the hdmi input right away.
HDMI has to be able to communicate with each other. In most cases the HDMI issue is with the device connected to the TV and not the TV itself. If you did firmware upgraded on the TV then the issue is with the laptop. Try the laptop on anther brand of TV and see what happens.
Jul 23, 2009 | Olevia LT32HVM 32 in. LCD Television
TV will not power on
You might want to try downloading the firmware again to see if it grabs it.. i heard if you re try doing the firmware it will fix that problem.. it don't matter if it don't boot up but as long as you have power on the television you should abe able to re do it.. also one important thing .. you have to have a windows XP version for the firmware to work.. if you do the firmware with a windows vista PC then for sure the firmware will not work on the television and will damage the tv's main-board. ..If the television don't work after trying the firmware again then the main-board will have to be replace ..to get a repair quote please call this number at 866-965-3842 and ask to get a repair quote ...
Jul 09, 2009 | Olevia 237T 37 in. LCD TV
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
Firmware update Failed
I had the same problem with my olevia 242-T11. I flashed it with the wrong firmware and the TV would not even turn on. The blue LED light would still light up and my PC would still recognize a connection when i hooked it up to the USB cable connected to the TV.
I was fortunate to download the appropriate software. The software is called MTK_DownLoad1.exe. I know this is the correct software to use for Olevia 242-T11 and Olevia 237T. I do not know if this will work with other models.
Here is the link to the MTK_DownLoad1.exe
http://rapidshare.com/files/17475900...load1.zip.html
You will also need to install the USB to Serial driver before you are able to use the MTK Download Utility. The USB Driver is located at
http://rapidshare.com/files/17475900...river.zip.html
BE SURE ONLY TO UPDATE YOUR TV WITH THE CORRECT SOFTWARE OR YOU WILL BRICK IT. I was lucky enough to recover my TV and finally able to upgrade it to the correct firmware but my TV was non functional for about a week and this has been a huge headache and if i could go back in time i would definitely not do it so please ask yourself if its even worth it risking upgrading the firmware of a TV who parent company is reorganizing after declaring bankruptcy.
If you still want to do this, here are the firmwares for all the various Olevia models.
http://olevia.ftpaccess.cc/support/OLEVIA/
I hope this helps all the people who need to recover / unbrick their Olevia TV's. If the links are down or you need any help please ask for help in avsforums. My id is sammykismail on avsforums and i will try my best to help you.
Jun 23, 2008 | Olevia LT42HVi 42 in. LCD Television
HDMI is not working
Some Hdmi signals are not working with some tvs at this time. It is a fighting battle that tv techs are dealing withe everyday. At this point the tv manufactutre will tell us what I am about to tell you. Hook up the composite and wait for a firmware upgrade to fix this. A perfect way to see this is a problem between cable box and tv and not just your tv is to plug in a dvd player with hdmi out if it works firmware will need to be developed if not your tv needs to be exchanged or a new main board.
Josh
Feb 27, 2008 | Olevia LT32HVE 32 in. LCD Television
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Olevia LT42HVi 42 in. LCD Television Logo
756 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
