Question about HP VP 6210 Multimedia Projector
Hp vp 6210
I connected the projector to my laptop and i do not get a picture. it says it is searching for a source.
  • 115 Answers
Connect the laptop with projector and power up the projector and select the input 'computer' now start the laptop. the Projector will automatically detect the signal. secondly also chek with the display setting set to 800x600 then check with higher resolution.
Posted on Mar 29, 2008
SOURCE:
Is this projector high def
HI,
Its not an HD (1080p) projector. So it will not be able to show HD picture. In HD projectors there will be an input named HDMI( High-Definition Multimedia Interface ).This projector able to Show picture up to a resolution 1080i (HDTV) Though component video input.
Check the link for its spec
Specification
Ajin
Aug 10, 2012 | HP VP 6210 Multimedia Projector
Projector Pj556d can find my hp computer
on the laptop,you will need to press the Fn key and then the f1,f2,f3 ect key until you find the display key,hold down fn and press the key untill you clone the screen
Apr 10, 2010 | ViewSonic PJ551 Multimedia Projector
ViewSonic PJ402D Projector does says searching for source, what does this mean? Laptop does not even notice that projector is connected to it as well.
you need to hold function down and press something like F1 F2 F3 F4 maybe twice to clone the screen display and make sure your projector is on vga and there is a secure connection between your laptop and your projector.
Jan 21, 2010 | ViewSonic PJ402D DLP Projector
When plugged into the laptop it continues to say searching and never connects
first reset the settings to factory default. then make sure that the source resolution is 1024x768. select auto search source. swap cables. if still nothing, you need to flash the projector with the latest firmware (check the infocus website).
Nov 05, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Unable to transmit image to projector
Usually you can use a VGA connection cable to connect your computer with a projector. They also have inputs for s-video and RGB but these are much rarer on computers. Once you have connected the projector press the key on your keyboard that looks like a square with two lines on either side (mine is FN+F4) This will shuffle through different setups (mirrored to screen, extended to screen and back to normal) if this doesn't work try plugging in the vga cable and restarting the computer with the projector on.
Jan 06, 2009 | HP Pavilion dv4000 Notebook
I have a Lightware projector Model VP-800. It won't power on. Do you have a repair service in the 13211 zip code area?
good luck finding anyone to fix that, much less anyone who carries parts. you can try finding a service center by searching the lightware site.
Dec 16, 2008 | Lightware VP 800 Plus Multimedia Projector
Source of laptop
sometimes it helps to hook up laptop and then power everything up at once. Also check and make sure that you have the source looking for the laptop or have it on auto search for it may also need to the check the menu for the projector to see if the may have a manuel connect for the laptop to be able to view
Jan 25, 2008 | ViewSonic PJ551 Multimedia Projector
HP vp 6120 Projector
Hi there
Have you reset the lamp timer ?
If you have and the problem stil occurs you will have to replace the Ballast ( lamp's powersupply ) This is a very common problem with this specific HP model.
Dec 29, 2007 | HP Digital Projector Vp6120 Multimedia...
HP MP3 3222 Projector
you dont connect a projector to a tv. you connect a video source to the projector like a dvd player or a video machine.xbox 360 etc, the projector then projects the item connected to it, like your tv does when you connect similar items. The projector has a couple of inputs available to it ..this is why it is saying searching VGA and Composite video etc
Jun 14, 2007 | HP MP3220 Multimedia Projector
HP VP 6210 Multimedia Projector Logo
258 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
