Question about Iomega (33222) 80 GB Hard Drive
I dropped my hardrive and now it beaps and is not recognized.
I dropped the hard drive but grabbed the cord so it barely hit the floor but when I try to use it, it only beeps every few seconds and is not recognized on my computer no matter what I do. The light blinks and I can hear the hard drive start up but beeps instead of continuiosly running.
    Brigadier General:
  • 4,090 Answers
Sometimes even the slightest bump will offset the heads. Difficult to fix and guarantee that the data will be preserved.
Please rate my help++++Thanks for using FIXYA
Posted on May 12, 2010
Testimonial: "Thank you this was helpful. I would have liked a bit more information about what I could try to do and whether there may be some solution. But thank you at least I have an answer now."
  • dennis bullard May 12, 2010
    it requires special tools to try and re-align the heads, there is nothing YOU can really do that would be productive. Techs can recover the data using special techniques but it is usually expensive.
    Nettiser
Why the hardrive was wobbling while spinning and i can not access the hardrive?
Friend it is might just get corrupted or brocken check it quickly change it. This brocken hard drive can harm your system, what ever you do do it quickly.
Aug 26, 2014 | Western Digital HDD WD2002FAEX Caviar 2TB...
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
My hardrive recently died, and so I bought a new PATA drive to go with my Soyo KT333 Dragon Lite motherboard. I get an error message when I try installing the drive, saying a disk read error occured, hit...
Is your hard drive being properly recognized/ identified in your Bios you may have to check in there
as far as partitioning goes you should be able to do that when you reinstall the Operating system in the advanced mode depending on what operating system of course.
Dec 21, 2010 | Computers & Internet
Missing hard drive
1) Try to reseat the hard drive. Remove the Battery and the power adapter first. Follow the steps on removing the hard drive form here http://support.dell.com/support/edocs/systems/ins1525/en/SM/hdd.htm#wp1180023
place it back again. and turn it back on.
2) if it still does not work the best thing to do is to contact dell tech support for hard drive troubleshooting. they may require it to be sent to them specially if it is still within warranty.
Apr 28, 2010 | Dell Inspiron 1525 Notebook
External hardrive not beinfg recognized. After usb cord was unplug then re-pluged in.
Shut down your computer and unplug the device. Then turn your computer back on, log in, wait for it to finish loading, then connect the drive and turn it on.
Apr 03, 2010 | Western Digital Elements powered by WD 320...
HELP MY HARD DRIVE HAS GONE!
Ok to understand this , you dropped a 1 TB hard-drive external hard drive on the floor? Well considering that it is a external, the cases in most externals are meant to take a beating as well as the hard-drive it self. There is two possiblities I can think of, what could of happened. When the Hard-Drive hit the floor, it could of is disconnected the connection on the hard-drive itself inside the casing, which you will have to pop it open and reseat it. Or the hardrive, arm inside the hard-drive it self snapped or is misplaced, which is unrepairable. Open up the casing and looking for the hardrive it self. Towards the back of the hard-drive is where the connection of th drive is, it is eather sata or orginal set up with his pins based. Take the connection off and put it back on and see if that works, if it didnt, best advise would be is take in in and have the drive tested, see if its still operable.
DrakeTech
Feb 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have a WD portable 320G removable hardrive I can't get my computer to reconize it's plugged in. I tried changing the cords. No luck. Keeps trying to install then comes back unable do to either being...
Connect the external disk-drive to another computer.
If it still is not recognized, then you have a problem:
* the USB-to-disk-drive interface inside the case is faulty,
* the disk-drive inside the case is faulty.
If the former, disassemble the casing, and extract the disk-drive,
and temporarily connect it as an "internal" and "slave" disk-drive to your desktop, and see if you can read the files.
Dec 01, 2009 | Western Digital Computers & Internet
1TB Verbatim external hardrive not recognized
Try taking the drive out of the enclosure and buying a usb adaoter that will fir the interface the hard drive has...either EIDE or SATA, then hook that up to a usb port and see if the computer will load it. May be the controller card in the enclosure is your problem.
Sep 02, 2009 | Verbatim VER95327 USB Hard Drive
Dropped firelite: still spins but is not recognized
Ok same situation happened to me i dropped my Firelite 80Gig, drive would spin no light and the computer would not recognize the drive. All I did was open the case an saw the the internal hardrive had come loose from its pin connection. So all i did was pushed it back in and BAM now it works, hope this helps other people. Thanks C.J.
Mar 20, 2008 | SmartDisk FireLite 40 GB Hard Drive
Iomega (33222) 80 GB Hard Drive Logo
129 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
